[petsc-users] PetscSFBcastAndOpBegin() fails when called from MatDiagonalScale() for n_threads > 1 with "Wrong type of object"
Roland Richter
roland.richter at ntnu.no
Tue Jan 19 05:58:46 CST 2021
Hei,
thanks for the idea, that solved my problem! I noticed that I was
writing out of bounds in an earlier loop, which then resulted in the
behavior observed below.
Roland
Am 17.01.21 um 19:40 schrieb Stefano Zampini:
> Valgrind https://valgrind.org/ <https://valgrind.org/>
> Il Dom 17 Gen 2021, 21:28 Roland Richter <roland.richter at ntnu.no
> <mailto:roland.richter at ntnu.no>> ha scritto:
> Dear all,
> I am currently encountering issues in my program when calling
> MatDiagonalScale(matrix, NULL, vector) in an MPI-context for at
> least two threads. The backtrace from gdb (and the error output)
> tells me that the problem lies apparently in
> PetscSFBcastAndOpBegin(), with the exact error listed as
> /petsc/src/vec/is/sf/interface/sf.c Wrong type of object:
> Parameter # 1
> When printing the involved matrix and vector, everything looks as
> expected (the matrix is split over the processes equally with
> continuous rows, the vector is distributed over both processes).
> Is the issue that my vector is distributed over several processes?
> Or is there another issue I am not seeing here?
> I tried to narrow the problem down by writing a MWE, but was not
> able to reproduce it in a smaller scale. Therefore, are there
> other approaches I could try, too?
> Thanks!
> Regards,
> Roland Richter
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210119/ec28ce08/attachment.html>
