[petsc-users] Kokkos with OpenMP
Mark Adams mfadams at lbl.gov
Mon Jan 18 08:16:09 CST 2021
OK, this running and using OMP Fieldsplit/additive.
Kokkos does not have any solvers hooked up yet, but I have added an LU
interface that just uses AIJ's LU.
Junchao, I asked Kokkos about adding LU and they said that it is on the
todo list. Until they do that I can't use it for the paper, but if you want
to work on integrating solvers into aijkokkos I can do that and test with
GMRES/Jacobi.
On Mon, Jan 18, 2021 at 1:00 AM Barry Smith <bsmith at petsc.dev> wrote:
>   Mark,
>   Looks like you tried to do two things at once, you removed the fopenmp
> and put back the --with-cuda.
>   Like I said if you want PETSc to build OpenMP and CUDA you need to
> remove this line (and some others) from kokkos.py
>      if self.openmp.found + pthreadfound + self.cuda.found > 1:
>       raise RuntimeError("Kokkos only supports a single parallel system
> during its configuration")
> On Jan 17, 2021, at 9:39 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> Here is the problem. You set  --CXXOPTFLAGS="-g -O0 -fPIC  -fopenmp" to
>> indicate how to compile for OpenMP but when ./configure checks the
>> installed KokkosKernel include files it uses CXXPPFLAGS. (Since you
>> provided the flag CXXOPTFLAGS  ./configure never determines the flag to put
>> into CXXPPFLAGS.
>> It is more desirable if you do not provide -fPIC  -fopenmp.  ./configure
>> will figure them out for you.
> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210118/8f28dbb7/attachment.html>
