[petsc-users] Error of MatMPIAIJSetPreallocation
Qin Lu lu_qin_2000 at yahoo.com
Fri Jan 15 14:33:23 CST 2021
It turns out some values in d_nnz were wrong. The program runs fine after I fixed the issue.
Thank you all for your help!
Regards,Qin
Sent from Yahoo Mail for iPhone
On Thursday, January 14, 2021, 5:40 PM, Barry Smith <bsmith at petsc.dev> wrote:
A merge request to catch more cases of integer overflow https://gitlab.com/petsc/petsc/-/merge_requests/3562
On Jan 14, 2021, at 5:18 PM, Barry Smith <bsmith at petsc.dev> wrote:
  These giant sizes are sometime an indication of integer overflow. Did you previously build PETSc with the --with-64-bit-indices ? Are you sure the d_nnz and o_nnz arguments are correct and not too large?
  Barry
On Jan 14, 2021, at 4:13 PM, Matthew Knepley <knepley at gmail.com> wrote:
On Thu, Jan 14, 2021 at 4:38 PM Qin Lu <lu_qin_2000 at yahoo.com> wrote:
Hi Matthew,
Thanks for your response! Does CHKERRQ work for FORTRAN-90?
Yes, see the examples.
I linked my program with debug version of Petsc lib and got more error messages as attached below. I only used 8 processes, but the message said a big number, as well as a huge memory size, which must be wrong since the problem size is not very big. Does this mean the non-zero sizes passed to the subroutine are not correct?
Yes, the sizes passed are too large.
     Matt
Thanks,Qin
==== error messages =====
[2]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[2]PETSC ERROR: Out of memory. This could be due to allocating
[2]PETSC ERROR: too large an object or bleeding by not properly
[2]PETSC ERROR: destroying unneeded objects.
[2]PETSC ERROR: Memory allocated 0 Memory used by process 2049617920
[2]PETSC ERROR: Try running with -malloc_dump or -malloc_view for info.
[2]PETSC ERROR: Memory requested 18446744073458206720
[2]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[2]PETSC ERROR: Petsc Release Version 3.12.5, Mar, 29, 2020
On Thursday, January 14, 2021, 2:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
On Thu, Jan 14, 2021 at 11:58 AM Qin Lu via petsc-users <petsc-users at mcs.anl.gov> wrote:
Hello,
My program got error 55 from calling MatMPIAIJSetPreallocation with Petsc version 3.12.5, what does this error mean? Interestingly, the same program using an older version 3.4.2 works fine. I did make necessary interface change in my program when I upgraded to 3.12.5.
1) You should always call CHKERRQ(ierr) after a Petsc call. Then you will get the full error message and stack to send in.
2) Your error code is here:
  https://gitlab.com/petsc/petsc/-/blob/v3.12.5/include/petscerror.h#L17
3) It is a memory error. You asked for more memory than your machine could allocate.
     Matt
Thanks in advance for your help.
Regards,Qin
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210115/a5759df8/attachment.html>
