[petsc-users] DMPlex with dof in cells AND at nodes
Wed Jan 13 08:00:17 CST 2021
On Tue, Jan 12, 2021 at 4:12 PM Thibault Bridel-Bertomeu <
thibault.bridelbertomeu at gmail.com> wrote:
> Good evening Matthew,
> Thank you for your answer, and sorry for the delay in mine ! I am trying
> to figure things out but when one gets in the distribution of a DMPlex, it
> becomes quite complex!
> Le lun. 11 janv. 2021 à 16:24, Matthew Knepley <knepley at gmail.com> a
> écrit :
>> On Mon, Jan 11, 2021 at 6:41 AM Thibault Bridel-Bertomeu <
>>> Dear all,
>>> I haven't been on this mailing list since december, so first of all,
>>> happy new year to everyone !
>>> I am facing another challenge with the DMPlex structure : although I am
>>> doing cell-centered finite volume (using PetscFV), I also need to do some
>>> manipulations and store information that are vertex-based.
>>> The problem I have is when I run the code in parallel : when I visualize
>>> the nodal data using a vtk viewer, it shows NaN at all the vertices in
>>> close proximity to the MPI partition line.
>>> Here is how I proceed to work on the vertex-based data :
>>> First comes the creation of the DM that I'll be using for the
>>> cell-centered FVM
>>> call DMPlexCreateFromFile(comm, name, PETSC_TRUE, dm, ierr)
>>> call DMSetBasicAdjacency(dm, PETSC_TRUE, PETSC_TRUE, ierr)
>>> call DMPlexDistribute(dm, 1, PETSC_NULL_SF, dmDist, ierr)
>>> dm = dmDist
>>> call DMConstructGhostCells(dm, ..., ..., dmGhost, ierr)
>>> dm = dmGhost
>>> I set both boolean to PETSC_TRUE in the SetBasicAdjacency so even in MPI
>>> the neighbouring relationships are conserved for all strata. Is that true ?
>>> Like, does doing this actually enable to get all the transitive closure of
>>> a given vertex, even if part of it is in another MPI block ?
>> What you say should be true, but it is not. When I designed everything, I
>> was very much stuck in the traditional mesh way of looking at things, and
>> made some limiting decisions. You can still get what you want (almost), but
>> you need to distribute the mesh with an overlap of 1. If you do, then you
>> can get the transitive support of vertices.
> I actually already distribute the mesh with an overlap of 1, but the
> result is the same. Do I need to re-distribute the clone "dmNodal" somehow
> ? Is the cloning process maybe not preserving the MPI support of the
> different strata ?
No. However, it is easy to check what you have using -dm_view. I would
encourage you to put
  DMViewFromOptions(dm, NULL, "-dm_view");
  DMViewFromOptions(dmNodal, NULL, "-nodal_dm_view");
so that you can give those options and send the output (for a very simple
mesh) with the emails. What you should
see is that for both meshes, the number of local cells adds up to more than
the number of global cells.
> The problem is basically that many places in the code assume that the
>> overlap always contains the closure of any point in it. It is difficult to
>> be able to switch this assumption to the star (transitive support)so I have
>> not done that yet.
>>> Then I need a vertex-based DM, so I figure it's pretty much what's done
>>> in CreateMassMatrix in TS ex11.c.
>>> call DMClone(dm, dmNodal, ierr)
>>> call DMGetCoordinateSection(dm, coordSection, ierr); CHKERRA(ierr)
>>> call DMGetCoordinatesLocal(dm, coordinates, ierr); CHKERRA(ierr)
>>> call DMSetCoordinateSection(dmNodal, PETSC_DETERMINE, coordSection,
>>> ierr);
>>> call PetscSectionCreate(PETSC_COMM_WORLD, sectionNodal, ierr);
>>> CHKERRA(ierr)
>>> call DMPlexGetDepthStratum(dm, 0, vstart, vend, ierr); CHKERRA(ierr)
>>> call PetscSectionSetChart(sectionNodal, vstart, vend, ierr);
>>> CHKERRA(ierr)
>>> do inode = vstart, vend-1
>>>  ! 3 dof per node, ndim = 3
>>> call PetscSectionSetDof(sectionNodal, inode, ndim, ierr); CHKERRA(ierr)
>>> end do
>>> call PetscSectionSetUp(sectionNodal, ierr); CHKERRA(ierr)
>>> call DMSetLocalSection(dmNodal, sectionNodal, ierr); CHKERRA(ierr)
>>> call PetscSectionDestroy(sectionNodal, ierr); CHKERRA(ierr)
>>> From what I understood, this new dmNodal basically has all the
>>> characteristics of the ori dm, except it's primary layer is vertex-based
>>> with 3 DOF per vertex.
>> Take out the coordinate stuff above. This is now handled internally in a
>> better way. Other than that, it looks good.
> You mean the SetCoordinateSection is already handled by the cloning
> process ?
Yes.
>>> Then I get a local vector and work on it :
>>> call DMGetLocalVector(dmNodal, nodalvec, ierr)
>>> call VecGetArrayF90(nodalvec, nodalvecarray, ierr)
>>> call DMPlexGetDepthStratum(dm, 2, fstart, fend, ierr)
>>> ! For each node ...
>>> A = 0 ! matrix, ndim x ndim
>>> b = 0 ! vector, ndim
>>> call DMPlexGetTransitiveClosure(dmNodal, inode, PETSC_FALSE,
>>> vertexclosure, ierr);
>>> ! For each face attached to that node
>>> do iface = 1, size(vertexclosure)
>>> if ((vertexclosure(iface) < fstart) .or. (vertexclosure(iface) >= fend))
>>> cycle
>>> A = A + ...
>>> b = b + ...
>>> end do
>>> nodalvecarray(1+(inode-vstart)*ndim:3+(inode-vstart)*ndim) = matmul(A, b)
>>> end do
>> There are some subtleties here I think. You are looping over all
>> vertices, but you only own some of them.
> Here I am quite surprised by your remark : from the random print I did,
> the DMPlexGetDepthStratum returns different vstart and vend for different
> MPI processes, hence I assumed it was a local numbering.
It is a local numbering. If you have a mesh partition, it is usually to
have vertices present in multiple local meshes. We think of one process as
"owning" the vertex. That is what I meant here.
> And then I assumed that, with the DMPlexDistribute, it ensured that the
> "vertexclosure"
This is the wrong terminology. Closures mean including the boundary of
something. Vertices have no boundary. You want the dual notion "support",
or its transitive closure "star". So is the vertex star included when
distributing? No, only the point closure is guaranteed when distributing.
This was the point of my explanation. However, if you request overlap = 1,
then you get everything in the star of the original boundary.
> contained (among others) all the faces connected to each "inode", even if
> the closure is spread among multiple MPI processes. So you mean that all
> these assumptions are actually wrong to some degree ?
>> What do you do when putting these values in the global vector? I think
>> there are at least three choices:
>> 1) Everyone has everything, so you compute all the vertex stuff
>> redundantly, and then use INSERT_VALUES for the scatter
>> 2) Only vertices are redundant, so the transitive supports of vertices
>> are partial but non-overlapping, and you use ADD_VALUES for the scatter
>> 3) Only cells are redundant, so you do the complete vertex computation
>> only for local vertices
> I distributed with overlap = 1, so I expect I have a halo of redundant
> cells in each MPI block (option no. 3).
Yes.
> With the (..., PETSC_TRUE, PETSC_TRUE, ...) setting of the distribute
> however, I also expected to have a halo of vertices and a halo of edges and
> a halo of faces. Therefore, completing the vertex computation only for
> local vertices should have been fine since anyways even local vertices know
> their complete closure in terms of faces,
Yes, this should work.
> but I am missing something because it does not turn out right ...
Start with a very simple mesh, say 2 cells or 4 cells. Then you can print
everything out.
     Matt
>>> Then I want to visualize it :
>>> call VecRestoreArrayF90(nodalvec, nodalvecarray, ierr)
>>> call DMCreateGlobalVector(dmNodal, globalnodalvec, ierr)
>>> call DMLocalToGlobal(dmNodal, nodalvec, INSERT_VALUES, globalnodalvec,
>>> ierr)
>>> call PetscViewerCreate(PETSC_COMM_WORLD, vtkViewer, ierr); CHKERRA(ierr)
>>> call PetscViewerSetType(vtkViewer, PETSCVIEWERVTK, ierr); CHKERRA(ierr)
>>> call PetscViewerFileSetName(vtkViewer, "toto.vtk", ierr); CHKERRA(ierr)
>>> call VecView(globalnodalvec, vtkViewer, ierr); CHKERRA(ierr)
>>> call PetscViewerDestroy(vtkViewer, ierr); CHKERRA(ierr)
>>> In the toto.vtk file, I get vertex-based values as expected, and the
>>> whole shebang works in sequential. Now when I run it in parallel, I get
>>> vertex-based values inside the MPI blocks, but in the neighbourhood of the
>>> join between the MPI blocks, all the vertex-based values are NaN (see
>>> attachment).
>> If you have redundant cells, meaning you distributed with overlap = 1,
>> did you remember to full up the values for those ghost cells using
>> DMGlobalToLocal() or something like that? If not, they will start as NaNs.
> Indeed, in the vertex computation, at some point I use the values in the
> cells. But I got the solution vector from TSGetSolution, then I do a
> GlobalToLocal, then I even add a InsertBoundaryValues to fill the ghost
> cells correctly.
> Even by doing this, when I print the nodalvecarray on each process, they
> somehow contain some NaNs. This means, I think, that at some point, a given
> vertex tries to get the information of a face that is supposed to be in its
> closure but is actually not .. (?)
> Thank you for your help and feedback !
> Cheers,
> Thibault
>>   Thanks,
>>      Matt
>>> All in all, I think I do not understand fully the consequences of the
>>> DMPlexDistribute with useCone=true & useClosure=true ... but I cannot
>>> figure out where the NaN are coming from : is it because the vertices do
>>> not actually know all their closure through the MPI join, or is it some
>>> Global / Local error I made ?
>>> Thank you very much in advance for your support !!
>>> Thibault
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210113/0493f97e/attachment-0001.html>
