[petsc-users] calling both MatSeqAIJSetPreallocation and MatMPIAIJSetPreallocation
Sam Guo
sam.guo at cd-adapco.com
Mon Jan 11 17:58:00 CST 2021
Thanks!
On Mon, Jan 11, 2021 at 2:40 PM Barry Smith <bsmith at petsc.dev> wrote:
> Sam,
> In the master development branch of PETSc Stefano has started to add
> support for directly providing matrix entries in "coordinate" form (COO)
> (the triple arrays you use).
> It supports MatSetPreallocationCOO() and MatSetValuesCOO().
> Currently Stefano has optimized it for use with GPUs but it will also
> work for CPUs and we can add optimizations in the future.
> You might consider using these in your code instead of managing the
> setting of each value individually.
> Barry
> On Jan 11, 2021, at 3:45 PM, Sam Guo <sam.guo at cd-adapco.com> wrote:
> Ok, thanks.
> On Mon, Jan 11, 2021 at 1:38 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Jan 11, 2021 at 4:32 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>> A follow up question: if I call preallocation, is there any
>>> performance difference between
>>> MatSetValues <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetValues.html#MatSetValues>(mat,1,&I,1,&J,&v,INSERT_VALUES <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/INSERT_VALUES.html#INSERT_VALUES>); // insert value one by one
>>> vs
>>> MatSetValues <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetValues.html#MatSetValues>(Mat <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat> mat,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> m,const PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> idxm[],PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> n,const PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> idxn[],const PetscScalar <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscScalar.html#PetscScalar> v[],InsertMode <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/InsertMode.html#InsertMode> addv) // insert multiple values
>>> My input is triple arrays
>>> vector<int> r;
>>> vector<int> c;
>>> vector<double> a;
>>> where r/c are not sorted by rows/cols. I don't want to waste memory/time to create idxm/idxn unless there is a performance penalty.
>> It is cheaper to insert many values than sequences of single values.
>> However, allocating memory is much much more expensive. As with most
>> performance questions, there is no substitute for experiments.
>> Thanks,
>> Matt
>>> Thanks,
>>> Sam
>>> On Mon, Jan 11, 2021 at 12:27 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>> Thanks!
>>>> On Mon, Jan 11, 2021 at 12:25 PM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Mon, Jan 11, 2021 at 3:00 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>>> Dear PETSc Dev Team,
>>>>>> The documentation recommends calling both of the above
>>>>>> preallocation routines for simplicity. Do we waste memory by calling both?
>>>>> No. Only one will function, depending on the matrix type.
>>>>> Thanks,
>>>>> Matt
>>>>>> Thanks,
>>>>>> Sam
>>>>>> MATAIJMATAIJ
>>>>>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATAIJ.html#MATAIJ> =
>>>>>> "aij" - A matrix type to be used for sparse matrices. This matrix type is
>>>>>> identical to MATSEQAIJ
>>>>>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATSEQAIJ.html#MATSEQAIJ> when
>>>>>> constructed with a single process communicator, and MATMPIAIJ
>>>>>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATMPIAIJ.html#MATMPIAIJ> otherwise.
>>>>>> As a result, for single process communicators,
>>>>>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSeqAIJSetPreallocation.html#MatSeqAIJSetPreallocation> is
>>>>>> supported, and similarly MatMPIAIJSetPreallocation
>>>>>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html#MatMPIAIJSetPreallocation>()
>>>>>> is supported for communicators controlling multiple processes. It is
>>>>>> recommended that you call both of the above preallocation routines for
>>>>>> simplicity.
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210111/79f62a22/attachment-0001.html>
