[petsc-users] calling both MatSeqAIJSetPreallocation and MatMPIAIJSetPreallocation
Sam Guo sam.guo at cd-adapco.com
Mon Jan 11 15:45:41 CST 2021
Ok, thanks.
On Mon, Jan 11, 2021 at 1:38 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Jan 11, 2021 at 4:32 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>> A follow up question: if I call preallocation, is there any
>> performance difference between
>> MatSetValues <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetValues.html#MatSetValues>(mat,1,&I,1,&J,&v,INSERT_VALUES <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/INSERT_VALUES.html#INSERT_VALUES>); // insert value one by one
>> vs
>> MatSetValues <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSetValues.html#MatSetValues>(Mat <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat> mat,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> m,const PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> idxm[],PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> n,const PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> idxn[],const PetscScalar <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscScalar.html#PetscScalar> v[],InsertMode <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/InsertMode.html#InsertMode> addv) // insert multiple values
>> My input is triple arrays
>> vector<int> r;
>> vector<int> c;
>> vector<double> a;
>> where r/c are not sorted by rows/cols. I don't want to waste memory/time to create idxm/idxn unless there is a performance penalty.
> It is cheaper to insert many values than sequences of single values.
> However, allocating memory is much much more expensive. As with most
> performance questions, there is no substitute for experiments.
>   Thanks,
>      Matt
>> Thanks,
>> Sam
>> On Mon, Jan 11, 2021 at 12:27 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>> Thanks!
>>> On Mon, Jan 11, 2021 at 12:25 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, Jan 11, 2021 at 3:00 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>> Dear PETSc Dev Team,
>>>>>    The documentation recommends calling  both of the above
>>>>> preallocation routines for simplicity. Do we waste memory by calling both?
>>>> No. Only one will function, depending on the matrix type.
>>>>   Thanks,
>>>>      Matt
>>>>> Thanks,
>>>>> Sam
>>>>> MATAIJMATAIJ
>>>>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATAIJ.html#MATAIJ> =
>>>>> "aij" - A matrix type to be used for sparse matrices. This matrix type is
>>>>> identical to MATSEQAIJ
>>>>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATSEQAIJ.html#MATSEQAIJ> when
>>>>> constructed with a single process communicator, and MATMPIAIJ
>>>>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATMPIAIJ.html#MATMPIAIJ> otherwise.
>>>>> As a result, for single process communicators,
>>>>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSeqAIJSetPreallocation.html#MatSeqAIJSetPreallocation> is
>>>>> supported, and similarly MatMPIAIJSetPreallocation
>>>>> <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html#MatMPIAIJSetPreallocation>()
>>>>> is supported for communicators controlling multiple processes. It is
>>>>> recommended that you call both of the above preallocation routines for
>>>>> simplicity.
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210111/fe3a1bd3/attachment.html>
