[petsc-users] convergence problem- 3D Cahn Hillard
    Sepideh Kavousi
    skavou1 at lsu.edu
    Thu Jan  7 12:48:34 CST 2021
I use finite difference and, as an example,  the discretization of Pxx is:
 Pxx=((aY[k][j][i+1].p+aY[k][j][i-1].p-2.0*aY[k][j][i].p)/hx2);
I ran the code with valgrind and it seems there is a memory leak problem.
I am trying to figure out what is causing the memory error.
Best,
Sepideh
Sent: Tuesday, January 5, 2021 10:31 PM
To: Matthew Knepley <knepley at gmail.com>; Barry Smith <bsmith at petsc.dev>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Sepideh Kavousi <skavou1 at lsu.edu>
Subject: Re: [petsc-users] convergence problem- 3D Cahn Hillard
Matthew Knepley <knepley at gmail.com> writes:
> On Tue, Jan 5, 2021 at 9:52 PM Barry Smith <bsmith at petsc.dev> wrote:
>> Ah, -snes_fd_color so it was already using finite differencing with
>> coloring to compute the Jacobian which explains why the differences below
>> are exactly zero.
>> Implicit time-step schemes essentially add terms like I/dt  to the
>> Jacobian evaluation (and the function defining the ODE) so for tiny
>> time-steps the nonlinear system gets easier and easier to solve (the
>> nonlinear function becomes linear) But we didn't see that with your earlier
>> run where  dt 3.72529e-13 (which is absurdly small).  for tiny time-steps
>> SNES still made no progress. It is hard to understand how this is possible,
>> regardless of the problem you are solving.
>> I would next run the code with valgrind to insure there are no issues of
>> memory corruption or un-initialized data.
>> How are you computing
>> (dp/dt)*(Pxx+Pyy+Pzz)
>> That is, how are you computing Pxx etc?
>> Are you using finite elements for the U and P model? Exactly what elements?
> I agree with Barry. This does not seem to make sense, so I would expect
> some kind of inconsistent discretization, or other
> mathematical problem which makes your system unsolvable.
Try -mat_fd_type ds before ruling out sensitivity to differencing parameter.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210107/35a18994/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210107/35a18994/attachment-0001.txt>
