[petsc-users] MatScale returns different results depending on matrix size
Barry Smith
bsmith at petsc.dev
Wed Jan 6 12:44:59 CST 2021
$ ./main -start_in_debugger noxterm
PETSC: Attaching lldb to ./main of pid 17914 on Barry-Smiths-MacBook-Pro.local
(lldb) process attach --pid 17914
warning: (x86_64) /Users/barrysmith/soft/clang-ifort/lib/libmpifort.12.dylib empty dSYM file detected, dSYM was created with an executable with no debug info.
warning: (x86_64) /Users/barrysmith/soft/clang-ifort/lib/libmpi.12.dylib empty dSYM file detected, dSYM was created with an executable with no debug info.
warning: (x86_64) /Users/barrysmith/soft/clang-ifort/lib/libpmpi.12.dylib empty dSYM file detected, dSYM was created with an executable with no debug info.
Process 17914 stopped
* thread #1, queue = 'com.apple.main-thread', stop reason = signal SIGSTOP
frame #0: 0x00007fff733cb756 libsystem_kernel.dylib`__semwait_signal + 10
libsystem_kernel.dylib`__semwait_signal:
-> 0x7fff733cb756 <+10>: jae 0x7fff733cb760 ; <+20>
0x7fff733cb758 <+12>: movq %rax, %rdi
0x7fff733cb75b <+15>: jmp 0x7fff733ca22d ; cerror
0x7fff733cb760 <+20>: retq
Target 0: (main) stopped.
Executable module set to "/Users/barrysmith/Src/petsc/src/ksp/ksp/tutorials/main".
Architecture set to: x86_64h-apple-macosx-.
(lldb) b MatScale
Breakpoint 1: where = libpetsc.3.014.dylib`MatScale + 48 at matrix.c:5281:3, address = 0x0000000102f62090
(lldb) c
1.0230000000000000e+03
* thread #1, queue = 'com.apple.main-thread', stop reason = breakpoint 1.1
frame #0: 0x0000000102f62090 libpetsc.3.014.dylib`MatScale(mat=0x00007fa5040c9870, a=0.01 + 0i) at matrix.c:5281:3
5278 {
5279 PetscErrorCode ierr;
5280
(lldb) c
0001e+01 1.0230000000000000e+01
[ 0]32 bytes PetscPushErrorHandler() line 161 in /Users/barrysmith/Src/petsc/src/sys/error/err.c
Process 17914 exited with status = 0 (0x00000000)
I see no issue. Code is, of course, built with complex.
Barry
> On Jan 6, 2021, at 11:31 AM, Roland Richter <roland.richter at ntnu.no> wrote:
> Hei,
> I removed all dependencies to armadillo and other not directly necessary packages, and attached both CMakeLists.txt and main-file. Even though I am only having PETSc as main dependence I still have the same issues. For a scaling factor of 0.1 and a matrix size of [1024, 1024] it works fine, for a scaling factor of 0.01 on the same matrix the apparent scaling factor is suddenly 1e-8.
> Thank you for your help!
> Regards,
> Roland
> Am 06.01.21 um 17:36 schrieb Matthew Knepley:
>> On Wed, Jan 6, 2021 at 11:05 AM Roland Richter <roland.richter at ntnu.no <mailto:roland.richter at ntnu.no>> wrote:
>> Hei,
>> I ran the program in both versions using "valgrind --tool=memcheck --leak-check=full --show-leak-kinds=all <binary> -malloc_debug". I got
>> ==3059== LEAK SUMMARY:
>> ==3059== definitely lost: 12,916 bytes in 32 blocks
>> ==3059== indirectly lost: 2,415 bytes in 2 blocks
>> ==3059== possibly lost: 0 bytes in 0 blocks
>> ==3059== still reachable: 103,511 bytes in 123 blocks
>> ==3059== suppressed: 0 bytes in 0 blocks
>> but none of the leaks is related to the scaling-function itself.
>> Did I miss something here?
>> Here is my analysis. It is certainly the case that MatScale() does not mysteriously scale by other numbers.
>> It is used all over the place in tests, and in the code. Your test requires another package. Thus, it seems
>> reasonable to guess that a bad interaction with that package (memory overwrite, conflicting layout or format, etc.)
>> is responsible for the behavior you see.
>> Thanks,
>> Matt
>> Thanks!
>> Am 06.01.21 um 15:26 schrieb Matthew Knepley:
>>> On Wed, Jan 6, 2021 at 2:41 AM Roland Richter <roland.richter at ntnu.no <mailto:roland.richter at ntnu.no>> wrote:
>>> Hei,
>>> I added one additional function to the code:
>>> void test_scaling_petsc_pointer(const Mat &in_mat,
>>> Mat &out_mat,
>>> const PetscScalar &scaling_factor) {
>>> MatCopy (in_mat, out_mat, SAME_NONZERO_PATTERN);
>>> PetscScalar *mat_ptr;
>>> MatDenseGetArray (out_mat, &mat_ptr);
>>> PetscInt r_0, r_1;
>>> MatGetLocalSize (out_mat, &r_0, &r_1);
>>> for(int i = 0; i < r_0 * r_1; ++i)
>>> *(mat_ptr + i) = (*(mat_ptr + i) * scaling_factor);
>>> MatAssemblyBegin (out_mat, MAT_FINAL_ASSEMBLY);
>>> MatAssemblyEnd (out_mat, MAT_FINAL_ASSEMBLY);
>>> When replacing test function test_scaling_petsc() with test_scaling_petsc_pointer() everything works as it should, but I do not understand why.
>>> Do you have any suggestions?
>>> The easiest explanation is that you have a memory overwrite in the code somewhere. Barry's suggestion to use
>>> valgrind is good.
>>> Matt
>>> Thanks!
>>> Am 05.01.21 um 15:24 schrieb Roland Richter:
>>>> Hei,
>>>> the code I attached to the original mail should work out of the box, but requires armadillo and PETSc to compile/run. Armadillo stores the data in column-major order, and therefore I am transposing the matrices before and after transferring using .st().
>>>> Regards,
>>>> Roland
>>>> Am 05.01.21 um 15:21 schrieb Matthew Knepley:
>>>>> On Tue, Jan 5, 2021 at 7:57 AM Roland Richter <roland.richter at ntnu.no <mailto:roland.richter at ntnu.no>> wrote:
>>>>> Hei,
>>>>> I would like to scale a given matrix with a fixed scalar value, and
>>>>> therefore would like to use MatScale(). Nevertheless, I observed an
>>>>> interesting behavior depending on the size of the matrix, and currently
>>>>> I am not sure why.
>>>>> When running the attached code, I intend to divide all elements in the
>>>>> matrix by a constant factor of 10. If I have three or fewer rows and
>>>>> 1024 columns, I get the expected result. If I have four or more rows
>>>>> (with the same number of columns), suddenly my scaling factor seems to
>>>>> be 0.01 instead of 0.1 for the PETSc-matrix. The armadillo-based matrix
>>>>> still behaves as expected.
>>>>> 1) It looks like you assume the storage in your armadillo matrix is row major. I would be surprised if this was true.
>>>>> 2) I think it is unlikely that there is a problem with MatScale, so I would guess either you have a memory overwrite
>>>>> or are misinterpreting your output. If you send something I can run, I will figure out which it is.
>>>>> Thanks,
>>>>> Matt
>>>>> I currently do not understand that behavior, but do not see any problems
>>>>> with the code either. Are there any possible explanations for that behavior?
>>>>> Thank you very much,
>>>>> regards,
>>>>> Roland Richter
>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>>> -- Norbert Wiener
>> -- Norbert Wiener
> <main.cpp><CMakeLists.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210106/6d4602b0/attachment-0001.html>
