[petsc-users] MatScale returns different results depending on matrix size
Roland Richter
roland.richter at ntnu.no
Wed Jan 6 10:05:25 CST 2021
Hei,
I ran the program in both versions using "valgrind --tool=memcheck
--leak-check=full --show-leak-kinds=all <binary> -malloc_debug". I got
==3059== LEAK SUMMARY:
==3059== definitely lost: 12,916 bytes in 32 blocks
==3059== indirectly lost: 2,415 bytes in 2 blocks
==3059== possibly lost: 0 bytes in 0 blocks
==3059== still reachable: 103,511 bytes in 123 blocks
==3059== suppressed: 0 bytes in 0 blocks
but none of the leaks is related to the scaling-function itself.
Did I miss something here?
Thanks!
Am 06.01.21 um 15:26 schrieb Matthew Knepley:
> On Wed, Jan 6, 2021 at 2:41 AM Roland Richter <roland.richter at ntnu.no
> <mailto:roland.richter at ntnu.no>> wrote:
> Hei,
> I added one additional function to the code:
> /void test_scaling_petsc_pointer(const Mat &in_mat,//
> // Mat &out_mat,//
> // const PetscScalar
> &scaling_factor) {//
> // MatCopy (in_mat, out_mat, SAME_NONZERO_PATTERN);//
> // PetscScalar *mat_ptr;//
> // MatDenseGetArray (out_mat, &mat_ptr);//
> // PetscInt r_0, r_1;//
> // MatGetLocalSize (out_mat, &r_0, &r_1);//
> // for(int i = 0; i < r_0 * r_1; ++i)//
> // *(mat_ptr + i) = (*(mat_ptr + i) * scaling_factor);//
> // MatAssemblyBegin (out_mat, MAT_FINAL_ASSEMBLY);//
> // MatAssemblyEnd (out_mat, MAT_FINAL_ASSEMBLY);//
> When replacing test function /test_scaling_petsc()/ with
> /test_scaling_petsc_pointer()/ everything works as it should, but
> I do not understand why.
> Do you have any suggestions?
> The easiest explanation is that you have a memory overwrite in the
> code somewhere. Barry's suggestion to use
> valgrind is good.
> Matt
> Thanks!
> Am 05.01.21 um 15:24 schrieb Roland Richter:
>> Hei,
>> the code I attached to the original mail should work out of the
>> box, but requires armadillo and PETSc to compile/run. Armadillo
>> stores the data in column-major order, and therefore I am
>> transposing the matrices before and after transferring using .st().
>> Thank you for your help!
>> Regards,
>> Roland
>> Am 05.01.21 um 15:21 schrieb Matthew Knepley:
>>> On Tue, Jan 5, 2021 at 7:57 AM Roland Richter
>>> <roland.richter at ntnu.no <mailto:roland.richter at ntnu.no>> wrote:
>>> Hei,
>>> I would like to scale a given matrix with a fixed scalar
>>> value, and
>>> therefore would like to use MatScale(). Nevertheless, I
>>> observed an
>>> interesting behavior depending on the size of the matrix,
>>> and currently
>>> I am not sure why.
>>> When running the attached code, I intend to divide all
>>> elements in the
>>> matrix by a constant factor of 10. If I have three or fewer
>>> rows and
>>> 1024 columns, I get the expected result. If I have four or
>>> more rows
>>> (with the same number of columns), suddenly my scaling
>>> factor seems to
>>> be 0.01 instead of 0.1 for the PETSc-matrix. The
>>> armadillo-based matrix
>>> still behaves as expected.
>>> 1) It looks like you assume the storage in your armadillo matrix
>>> is row major. I would be surprised if this was true.
>>> 2) I think it is unlikely that there is a problem with MatScale,
>>> so I would guess either you have a memory overwrite
>>> or are misinterpreting your output. If you send something I can
>>> run, I will figure out which it is.
>>> Thanks,
>>> Matt
>>> I currently do not understand that behavior, but do not see
>>> any problems
>>> with the code either. Are there any possible explanations
>>> for that behavior?
>>> Thank you very much,
>>> regards,
>>> Roland Richter
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to
>>> which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210106/6f79bd15/attachment-0001.html>
