[petsc-users] convergence problem- 3D Cahn Hillard
    Matthew Knepley
    knepley at gmail.com
    Tue Jan  5 14:53:49 CST 2021
On Tue, Jan 5, 2021 at 3:14 PM Sepideh Kavousi <skavou1 at lsu.edu> wrote:
> Dear Petsc Users
> I wrote a code in 2D solving PF equations for solidification of alloys. I
> have two variables in the equations 1-non-dimensional concentration (U) 2-
> order parameter (p). Everything is fine with this code.
> When I change the code to 3D, the code has convergence problems which I
> cannot solve it.
> I know the term which is causing problem is a term in the equation for U:
> (dp/dt)*(Pxx+Pyy+Pzz)
> where Pxx,Pyy,Pzz are the second derivative of order parameter in x,y,z,
> respectively.
> When I eliminate this term, the results of 2D and 3D are close to each
> other. But adding that term the time step should be reduced a lot to obtain
> convergence, otherwise the timestep does not converge. I have no idea how I
> should solve this problem.
>  I solve the equations considering (I chose based on suggestions of Moose
> for solving Cahn-hillard)
>  -ts_type bdf -ts_bdf_adapt -pc_type bjacobi -snes_linesearch_type l2
> -snes_type newtontr -ksp_type gmres -ksp_gmres_restart 1001 -sub_pc_type
> ilu -sub_ksp_type preonly
> Would you please help me solve this issue?
In order to see the solver you have we need the output of
  -ts_view
and then to see what is happening during the run we need
  -ts_monitor -snes_monitor -snes_linesearch_monitor
-ksp_monitor_true_residual
     Matt
> Best,
> sepideh
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210105/5861d5f7/attachment.html>
