[petsc-users] MatScale returns different results depending on matrix size
    Roland Richter
    roland.richter at ntnu.no
    Tue Jan  5 08:24:45 CST 2021
Hei,
the code I attached to the original mail should work out of the box, but
requires armadillo and PETSc to compile/run. Armadillo stores the data
in column-major order, and therefore I am transposing the matrices
before and after transferring using .st().
Thank you for your help!
Roland
Am 05.01.21 um 15:21 schrieb Matthew Knepley:
> On Tue, Jan 5, 2021 at 7:57 AM Roland Richter <roland.richter at ntnu.no
> <mailto:roland.richter at ntnu.no>> wrote:
>     Hei,
>     I would like to scale a given matrix with a fixed scalar value, and
>     therefore would like to use MatScale(). Nevertheless, I observed an
>     interesting behavior depending on the size of the matrix, and
>     currently
>     I am not sure why.
>     When running the attached code, I intend to divide all elements in the
>     matrix by a constant factor of 10. If I have three or fewer rows and
>     1024 columns, I get the expected result. If I have four or more rows
>     (with the same number of columns), suddenly my scaling factor seems to
>     be 0.01 instead of 0.1 for the PETSc-matrix. The armadillo-based
>     matrix
>     still behaves as expected.
> 1) It looks like you assume the storage in your armadillo matrix is
> row major. I would be surprised if this was true.
> 2) I think it is unlikely that there is a problem with MatScale, so I
> would guess either you have a memory overwrite
> or are misinterpreting your output. If you send something I can run, I
> will figure out which it is.
>   Thanks,
>      Matt
>     I currently do not understand that behavior, but do not see any
>     problems
>     with the code either. Are there any possible explanations for that
>     behavior?
>     Thank you very much,
>     regards,
>     Roland Richter
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210105/4bf6742c/attachment.html>
