[petsc-users] Caught signal number 11 SEGV
Matthew Knepley
knepley at gmail.com
Wed Feb 24 06:20:31 CST 2021
You have shut off the ability to use the debugger on your machine:
Attaching to program:
/home/fbrarda/cmdstan-petsc/examples/rosenbrock/rosenbrock, process 3903
Could not attach to process. If your uid matches the uid of the target
process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
again as the root user. For more details, see /etc/sysctl.d/10-ptrace.conf
ptrace: Operation not permitted.
You need to edit /proc/sys/kernel/yama/ptrace_scope and allow debugging on
your box.
Matt
On Wed, Feb 24, 2021 at 4:39 AM Francesco Brarda <brardafrancesco at gmail.com>
wrote:
> I have never used gdb.
> Using 0 as you suggested I got this output:
> $PETSC_DIR/$PETSC_ARCH/bin/mpirun -n 2
> examples/rosenbrock/rosenbrock optimize -start_in_debugger noxterm
> -debugger_nodes 0
> ** PETSc DEPRECATION WARNING ** : the option -debugger_nodes is deprecated
> as of version 3.14 and will be removed in a future release. Please use the
> option -debugger_ranks instead. (Silence this warning
> with -options_suppress_deprecated_warnings)
> PETSC: Attaching gdb to examples/rosenbrock/rosenbrock of pid 3903
> on srvulx13
> GNU gdb (Ubuntu 7.7.1-0ubuntu5~14.04.3) 7.7.1
> Copyright (C) 2014 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <
> http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law. Type "show copying"
> and "show warranty" for details.
> This GDB was configured as "x86_64-linux-gnu".
> Type "show configuration" for configuration details.
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>.
> Find the GDB manual and other documentation resources online at:
> <http://www.gnu.org/software/gdb/documentation/>.
> For help, type "help".
> Type "apropos word" to search for commands related to "word"...
> Reading symbols from examples/rosenbrock/rosenbrock...done.
> /home/fbrarda/cmdstan-petsc/3903: No such file or directory.
> (gdb) method = optimize
> optimize
> algorithm = lbfgs (Default)
> lbfgs
> method = optimize
> optimize
> lbfgs
> init_alpha = 0.001 (Default) init_alpha = 0.001 (Default)
> tol_obj = 9.9999999999999998e-13 (Default)
> tol_rel_obj = 10000 (Default)
> tol_grad = 1e-08 (Default)
> tol_rel_grad = 10000000 (Default)
> tol_param = 1e-08 (Default)
> history_size = 5 (Default)
> iter = 2000 (Default)
> save_iterations = 0 (Default) tol_rel_grad = 10000000 (Default)
> id = 0 (Default)
> data
> file = (Default)
> init = 2 (Default)
> random
> seed = 3666155654 (Default)
> output
> file = output.csv (Default)
> diagnostic_file = (Default)id = 0 (Default)
> data
> file = (Default)
> init = 2 (Default)
> refresh = 100 (Default)
> random
> output
> Initial log joint probability = -158.559
> Iter log prob ||dx|| ||grad|| alpha
> alpha0 # evals Notes
> 12 -0.253535 0.000284499 0.0383658 0.001
> 0.001 46 LS failed, Hessian reset
> 13 -0.253535 0.000284499 0.0383658 6.528
> 0.001 111 LS failed, Hessian reset
> Optimization terminated with error:
> Line search failed to achieve a sufficient decrease, no more
> progress can be made
> [0]PETSC ERROR: PetscAbortErrorHandler: main() line 12
> in src/cmdstan/main.cpp
> To prevent termination, change the error handler
> using PetscPushErrorHandler()
> Using only 1 process the code works.
> Francesco
> Il giorno 24 feb 2021, alle ore 07:14, Barry Smith <bsmith at petsc.dev> ha
> scritto:
> start_in_debugger noxterm -debugger_nodes 3
> Use -start_in_debugger noxterm -debugger_nodes 0
> when not opening windows for each debugger it is best to have the first
> rank associated with the tty as the debugger node
> On Feb 23, 2021, at 3:46 PM, Francesco Brarda <brardafrancesco at gmail.com>
> wrote:
> Using the command you suggested I got
> fbrarda at srvulx13:~/cmdstan-petsc$ $PETSC_DIR/$PETSC_ARCH/bin/mpirun -n 2
> -debugger_nodes 3
> option -debugger_ranks instead. (Silence this warning with
> method = optimize
> optimize
> lbfgs
> method = optimize
> optimize
> lbfgs
> tol_grad = 1e-08 (Default) tol_rel_obj = 10000 (Default)
> tol_param = 1e-08 (Default) tol_param = 1e-08 (Default)
> id = 0 (Default)
> data
> id = 0 (Default)
> data
> file = (Default)
> file = (Default)
> init = 2 (Default)
> random
> seed = 3623621468 (Default)
> output
> file = output.csv (Default)init = 2 (Default)
> random
> output
> Initial log joint probability = -195.984
> Iter log prob ||dx|| ||grad|| alpha alpha0
> # evals Notes
> 10 -0.97101 0.00292919 1.65855 0.001 0.001
> 12 -0.483952 0.001316 1.18542 0.001 0.001
> 77 LS failed, Hessian reset
> 13 -0.477916 0.0118542 0.163518 0.01 0.001
> 106 LS failed, Hessian reset
> [1]PETSC ERROR: #1 main() line 12 in src/cmdstan/main.cpp
> [1]PETSC ERROR: PETSc Option Table entries:
> [1]PETSC ERROR: -debugger_nodes 3
> [1]PETSC ERROR: -start_in_debugger noxterm
> [1]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov—————
> And then it does not go further. With the -debugger_ranks suggested, the
> output is the same. What do you think, please?
> I am using a cluster (one node, dual-socket system with twelve-core-CPUs),
> but when I do the ssh I do not use the -X flag, if that's what you mean.
> Thank you,
> Francesco
> Il giorno 23 feb 2021, alle ore 21:59, Matthew Knepley <knepley at gmail.com>
> ha scritto:
> On Tue, Feb 23, 2021 at 3:55 PM Francesco Brarda <
> brardafrancesco at gmail.com> wrote:
> Thank you for the quick response.
> Sorry, you are right. Here is the complete output:
> PETSC: Attaching gdb to examples/rosenbrock/rosenbrock of pid 47803 on
> display :0.0 on machine srvulx13
> PETSC: Attaching gdb to examples/rosenbrock/rosenbrock of pid 47804 on
> xterm: Xt error: Can't open display: :0.0
> xterm: DISPLAY is not set
> Do you have an Xserver running? If not, you can use
> -start_in_debugger noxterm -debugger_nodes 3
> and try to get a stack trace from one node.
> Thanks,
> Matt
> method = optimize
> optimize
> lbfgs
> method = optimize
> optimize
> lbfgs
> id = 0 (Default)
> data save_iterations = 0 (Default)
> id = 0 (Default)
> data
> file = (Default)
> file = (Default)
> init = 2 (Default)
> random
> seed = 3585768430 (Default)
> init = 2 (Default)
> random
> output
> output
> Initial log joint probability = -731.444
> # evals Notes
> [1]PETSC ERROR: PetscAbortErrorHandler: main() line 12 in
> To prevent termination, change the error handler using
> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> = PID 47804 RUNNING AT srvulx13
> = EXIT CODE: 134
> = CLEANING UP REMAINING PROCESSES
> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Aborted (signal 6)
> This typically refers to a problem with your application.
> Please see the FAQ page for debugging suggestions
> The code inside main.cpp is the following:
> #include <cmdstan/command.hpp>
> #include <stan/services/error_codes.hpp>
> #include <petsc.h>
> int main(int argc, char* argv[]) {
> PetscErrorCode ierr;
> ierr = PetscInitialize(&argc, &argv, 0, 0);CHKERRQ(ierr);
> try {
> ierr = cmdstan::command(argc, argv);CHKERRQ(ierr);
> } catch (const std::exception& e) {
> std::cout << e.what() << std::endl;
> ierr = stan::services::error_codes::SOFTWARE;CHKERRQ(ierr);
> ierr = PetscFinalize();CHKERRQ(ierr);
> return ierr;
> I highlighted the line 12. Although I read the page where the command
> PetscPushErrorHandler is explained and the example
> provided (src/ksp/ksp/tutorials/ex27.c), I do not understand how I should
> effectively use the command.
> Should I change the entire try/catch with
> PetscPushErrorHandler(PetscIgnoreErrorHandler,NULL); ?
> Best,
> Francesco
> Il giorno 23 feb 2021, alle ore 11:54, Matthew Knepley <knepley at gmail.com>
> ha scritto:
> On Tue, Feb 23, 2021 at 3:54 AM Francesco Brarda <
> Hi!
> I am very new to the PETSc world. I am working with a GitHub repo that
> uses PETSc together with Stan (a statistics open source software), here you
> can find the discussion.
> It has been defined a functor to convert EigenVector to PetscVec and
> viceversa, both sequentially and in parallel.
> The file using these functions does the conversions with the sequential
> setting. I changed to those using MPI, that is
> from EigenVectorToPetscVecSeq to EigenVectorToPetscVecMPI and so on because
> I want to evaluate the scaling.
> Running the example with mpirun -n 5 examples/rosenbrock/rosenbrock
> optimize in the debug mode I get the error Caught signal number 11 SEGV. I
> therefore used the option -start_in_debugger and I get the following:
> For some reason, the -start_in_debuggger option is not being seen. Are you
> showing all the output? Once the debugger is attached,
> you run the program (conr) and then when you hit the SEGV you get a stack
> trace (where).
> THanks,
> Matt
> [2]PETSC ERROR:
> [2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [2]PETSC ERROR: or see
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [2]PETSC ERROR: likely location of problem given in stack below
> [2]PETSC ERROR: --------------------- Stack Frames
> [2]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [2]PETSC ERROR: INSTEAD the line number of the start of the function
> [2]PETSC ERROR: is given.
> [3]PETSC ERROR:
> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [3]PETSC ERROR: or see
> [3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> [3]PETSC ERROR: likely location of problem given in stack below
> [3]PETSC ERROR: --------------------- Stack Frames
> [3]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [3]PETSC ERROR: INSTEAD the line number of the start of the function
> [3]PETSC ERROR: is given.
> [3]PETSC ERROR: PetscAbortErrorHandler: User provided function() line 0 in
> unknown file (null)
> [2]PETSC ERROR: PetscAbortErrorHandler: User provided function() line 0 in
> unknown file (null)
> = PID 22939 RUNNING AT srvulx13
> = EXIT CODE: 134
> I read the documentation regarding the PetscAbortErrorHandler, but I do
> not know where should I use it. How can I solve the problem?
> I hope I have been clear enough.
> Attached you can find also my configure.log and make.log files.
> Best,
> Francesco
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210224/1855cc10/attachment-0001.html>
