[petsc-users] Caught signal number 11 SEGV
Tue Feb 23 14:59:59 CST 2021
On Tue, Feb 23, 2021 at 3:55 PM Francesco Brarda <brardafrancesco at gmail.com>
wrote:
> Thank you for the quick response.
> Sorry, you are right. Here is the complete output:
> fbrarda at srvulx13:~/cmdstan-petsc$ $PETSC_DIR/$PETSC_ARCH/bin/mpirun -n
> 2 examples/rosenbrock/rosenbrock optimize -start_in_debugger
> PETSC: Attaching gdb to examples/rosenbrock/rosenbrock of pid 47803
> on display :0.0 on machine srvulx13
> PETSC: Attaching gdb to examples/rosenbrock/rosenbrock of pid 47804
> xterm: Xt error: Can't open display: :0.0
> xterm: DISPLAY is not set
Do you have an Xserver running? If not, you can use
  -start_in_debugger noxterm -debugger_nodes 3
and try to get a stack trace from one node.
    Matt
> method = optimize
>   optimize
>     algorithm = lbfgs (Default)
>       lbfgs
> method = optimize
>   optimize
>       lbfgs
>         init_alpha = 0.001 (Default)
>         tol_obj = 9.9999999999999998e-13 (Default)
>         tol_rel_obj = 10000 (Default)
>         tol_grad = 1e-08 (Default)
>         tol_rel_grad = 10000000 (Default)
>         tol_param = 1e-08 (Default)
>         history_size = 5 (Default)
>     iter = 2000 (Default)
>     save_iterations = 0 (Default)
> id = 0 (Default)
> data    save_iterations = 0 (Default)
> id = 0 (Default)
> data
>   file =  (Default)
>   file =  (Default)
> init = 2 (Default)
> random
>   seed = 3585768430 (Default)
> init = 2 (Default)
> random
> output
>   file = output.csv (Default)
> output
>   diagnostic_file =  (Default)
>   refresh = 100 (Default)
> Initial log joint probability = -731.444
>     Iter      log prob        ||dx||      ||grad||       alpha
>   alpha0  # evals  Notes
> [1]PETSC ERROR: PetscAbortErrorHandler: main() line 12
> in src/cmdstan/main.cpp
>   To prevent termination, change the error handler
> using PetscPushErrorHandler()
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   PID 47804 RUNNING AT srvulx13
> =   EXIT CODE: 134
> =   CLEANING UP REMAINING PROCESSES
> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Aborted (signal 6)
> This typically refers to a problem with your application.
> Please see the FAQ page for debugging suggestions
> The code inside main.cpp is the following:
> #include <cmdstan/command.hpp>
> #include <stan/services/error_codes.hpp>
> #include <petsc.h>
> int main(int argc, char* argv[]) {
>   PetscErrorCode ierr;
>   ierr = PetscInitialize(&argc, &argv, 0, 0);CHKERRQ(ierr);
>   try {
>     ierr = cmdstan::command(argc, argv);CHKERRQ(ierr);
>   } catch (const std::exception& e) {
>     std::cout << e.what() << std::endl;
>     ierr = stan::services::error_codes::SOFTWARE;CHKERRQ(ierr);
>   ierr = PetscFinalize();CHKERRQ(ierr);
>   return ierr;
> I highlighted the line 12. Although I read the page where the command
> PetscPushErrorHandler is explained and the example provided
> (src/ksp/ksp/tutorials/ex27.c), I do not understand how I should
> effectively use the command.
> Should I change the entire try/catch with PetscPushErrorHandler(
> PetscIgnoreErrorHandler,NULL); ?
> Best,
> Francesco
> Il giorno 23 feb 2021, alle ore 11:54, Matthew Knepley <knepley at gmail.com>
> ha scritto:
> On Tue, Feb 23, 2021 at 3:54 AM Francesco Brarda <
> brardafrancesco at gmail.com> wrote:
> Hi!
> I am very new to the PETSc world. I am working with a GitHub repo that
> uses PETSc together with Stan (a statistics open source software), here you
> can find the discussion.
> It has been defined a functor to convert EigenVector to PetscVec and
> viceversa, both sequentially and in parallel.
> The file using these functions does the conversions with the sequential
> setting. I changed to those using MPI, that is
> from EigenVectorToPetscVecSeq to EigenVectorToPetscVecMPI and so on because
> I want to evaluate the scaling.
> Running the example with mpirun -n 5 examples/rosenbrock/rosenbrock
> optimize in the debug mode I get the error Caught signal number 11 SEGV. I
> therefore used the option -start_in_debugger and I get the following:
> For some reason, the -start_in_debuggger option is not being seen. Are you
> showing all the output? Once the debugger is attached,
> you run the program (conr) and then when you hit the SEGV you get a stack
> trace (where).
>   THanks,
>     Matt
> [2]PETSC ERROR:
> [2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [2]PETSC ERROR: or see
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [2]PETSC ERROR: likely location of problem given in stack below
> [2]PETSC ERROR: ---------------------  Stack Frames
> [2]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [2]PETSC ERROR:       INSTEAD the line number of the start of the function
> [2]PETSC ERROR:       is given.
> [3]PETSC ERROR:
> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [3]PETSC ERROR: or see
> [3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> [3]PETSC ERROR: likely location of problem given in stack below
> [3]PETSC ERROR: ---------------------  Stack Frames
> [3]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [3]PETSC ERROR:       INSTEAD the line number of the start of the function
> [3]PETSC ERROR:       is given.
> [3]PETSC ERROR: PetscAbortErrorHandler: User provided function() line 0 in
>  unknown file (null)
>   To prevent termination, change the error handler using
> [2]PETSC ERROR: PetscAbortErrorHandler: User provided function() line 0 in
>  unknown file (null)
> =   PID 22939 RUNNING AT srvulx13
> =   EXIT CODE: 134
> I read the documentation regarding the PetscAbortErrorHandler, but I do
> not know where should I use it. How can I solve the problem?
> I hope I have been clear enough.
> Attached you can find also my configure.log and make.log files.
> Best,
> Francesco
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210223/21529869/attachment-0001.html>
