[petsc-users] headsup: switch git default branch from 'master' to 'main'
Lisandro Dalcin dalcinl at gmail.com
Tue Feb 23 13:52:21 CST 2021
May the force be with you, Satish.
On Tue, 23 Feb 2021 at 20:19, Satish Balay via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> All,
> This is a heads-up, we are to switch the default branch in petsc git
> repo from 'master' to 'main'
> [Will plan to do the switch on friday the 26th]
> We've previously switched 'maint' branch to 'release' before 3.14
> release - and this change (to 'main') is the next step in this direction.
> Satish
Lisandro Dalcin
Senior Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210223/1ecc4064/attachment.html>
