[petsc-users] Get the vertices composing the cells of a DMPlex Submesh
Fabien Vergnet
fabien.vergnet at sorbonne-universite.fr
Mon Feb 22 12:06:41 CST 2021
Hi Matthew and Stefano,
@Stefano, thank you for the explanation. DMPlexGetTransitiveClosure is exactly what I needed.
@Matthew, thank you for your advise on using DMPlexFilter, this is much better !
Fabien
> Le 22 févr. 2021 à 14:36, Matthew Knepley <knepley at gmail.com> a écrit :
> On Mon, Feb 22, 2021 at 6:28 AM Fabien Vergnet <fabien.vergnet at sorbonne-universite.fr <mailto:fabien.vergnet at sorbonne-universite.fr>> wrote:
> Dear PETSc community,
> Thank you for your amazing work. I discovered PETSc recently and I need your help for a project.
> As a training, I would like to assemble the Finite Element Matrix for the Poisson problem on a part of my mesh. So, I create a DMPlex from a .msh file and I create a Submesh with
> DMPlexCreateSubmesh(dm, label, 1, PETSC_TRUE, &subdm);
> I don't think you want this call. It is designed to pick out hypersurfaces. If you just want part of a mesh, DMPlexFilter is better.
> In order to assemble my Finite Element Matrix, I need to iterate over the cells of the mesh (which are triangles) and identify the vertices composing each cell.
> My question is the following : how can I get, for each cell, the vertices composing the cell ?
> I have tried to uninterpolate the subdm with DMPlexUninterpolate (with the objective to get the vertices from DMPlexGetCone) but it does not seem to work for a Submesh since I get the following error:
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Not for partially interpolated meshes
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.14.4, Feb 03, 2021
> [0]PETSC ERROR: Configure options --prefix=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/petsc-3.14.4-xtae5tcwlzkb4oiifbayj77bqlz5nngk --with-ssl=0 --download-c2html=0 --download-sowing=0 --download-hwloc=0 CFLAGS= FFLAGS= CXXFLAGS= --with-cc=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/openmpi-4.0.5-ygn7zymoy7crl7b4xsdkc4zmfojugmdy/bin/mpicc --with-cxx=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/openmpi-4.0.5-ygn7zymoy7crl7b4xsdkc4zmfojugmdy/bin/mpic++ --with-fc=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/openmpi-4.0.5-ygn7zymoy7crl7b4xsdkc4zmfojugmdy/bin/mpif90 --with-precision=double --with-scalar-type=real --with-shared-libraries=1 --with-debugging=0 --with-64-bit-indices=0 COPTFLAGS= FOPTFLAGS= CXXOPTFLAGS= --with-blaslapack-lib=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/openblas-0.3.13-6b3u6zc5j4hvauqh3ldcwnf7lm2o4vyl/lib/libopenblas.so --with-x=0 --with-clanguage=C --with-scalapack=0 --with-cuda=0 --with-metis=1 --with-metis-dir=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/metis-5.1.0-lm3k7dh2vslghqtqc6dvcpnc54bfpqq2 --with-hypre=1 --with-hypre-dir=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/hypre-2.20.0-4pyxhku65wb5lmh2fpflhmjmow2pbjg7 --with-parmetis=1 --with-parmetis-dir=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/parmetis-4.0.3-pfiam4ccxkyqpapejcdjtlyr6cyz7irc --with-mumps=0 --with-trilinos=0 --with-fftw=0 --with-valgrind=0 --with-gmp=0 --with-libpng=0 --with-giflib=0 --with-mpfr=0 --with-netcdf=0 --with-pnetcdf=0 --with-moab=0 --with-random123=0 --with-exodusii=0 --with-cgns=0 --with-memkind=0 --with-p4est=0 --with-saws=0 --with-yaml=0 --with-libjpeg=0 --with-cxx-dialect=C++11 --with-superlu_dist-include=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/superlu-dist-6.4.0-bagymefhq7s7gerf7jxwiv4fv7szoljh/include --with-superlu_dist-lib=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/superlu-dist-6.4.0-bagymefhq7s7gerf7jxwiv4fv7szoljh/lib/libsuperlu_dist.a --with-superlu_dist=1 --with-suitesparse=0 --with-ptscotch=0 --with-hdf5-include=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/hdf5-1.10.7-dkfs4ir3hlahyfs5z4xcmsf4ogklimji/include --with-hdf5-lib=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/hdf5-1.10.7-dkfs4ir3hlahyfs5z4xcmsf4ogklimji/lib/libhdf5.so --with-hdf5=1 --with-zlib-include=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/zlib-1.2.11-2pwsgfxppopolmjj6tf34k5jsaqzpodo/include --with-zlib-lib=/users/home/vergnet/apps/spack/opt/spack/linux-ubuntu20.04-zen2/gcc-9.3.0/zlib-1.2.11-2pwsgfxppopolmjj6tf34k5jsaqzpodo/lib/libz.so --with-zlib=1
> [0]PETSC ERROR: #1 DMPlexUninterpolate() line 1514 in /tmp/vergnet/spack-stage/spack-stage-petsc-3.14.4-xtae5tcwlzkb4oiifbayj77bqlz5nngk/spack-src/src/dm/impls/plex/plexinterpolate.c
> [0]PETSC ERROR: #2 assemble_mass() line 59 in /users/home/vergnet/codes/cilia/cilia/cpp/assembling.hpp
> Attached are a minimal working example, a mesh file and a makefile.
> The code does not seem to be attached.
> As Stefano says, you can use DMPlexGetTransitiveClosure() to get vertices, but if you actually want values attached to the
> vertices, it is easier to use DMPlexVecGetClosure().
> Thanks,
> Matt
> Any ideas or suggestions are more than welcome !
> Regards,
> Fabien
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210222/24e12e3f/attachment.html>
