[petsc-users] An issue about pipelined CG and Gropp's CG
赵刚 zhaog6 at lsec.cc.ac.cn
Thu Feb 18 00:38:22 CST 2021
Thank you a lot for your analysis and suggestions,  I quite agree with your opinion for the difference of theoretical and actual. I'll try to change into MPICH-3.4 rather than MVAPICH-2.3.5 I've used before.
Gang
-----原始邮件-----
发件人:"Barry Smith" <bsmith at petsc.dev>
发送时间:2021-02-18 13:09:43 (星期四)
收件人: "赵刚" <zhaog6 at lsec.cc.ac.cn>
抄送: PETSc <petsc-users at mcs.anl.gov>
主题: Re: [petsc-users] An issue about pipelined CG and Gropp's CG
  Here are the important operations from the -log_view (use a fixed sized font for easy reading).
No pipeline
Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
MatMult             5398 1.0 9.4707e+0012.6 1.05e+09 1.1 3.6e+07 6.9e+02 0.0e+00  3 52100100  0  10 52100100  0 124335
VecTDot            10796 1.0 1.4993e+01 8.3 3.23e+08 1.1 0.0e+00 0.0e+00 1.1e+04 16 16  0  0 67  55 16  0  0 67 24172
VecNorm             5399 1.0 6.2343e+00 4.4 1.61e+08 1.1 0.0e+00 0.0e+00 5.4e+03 10  8  0  0 33  33  8  0  0 33 29073
VecAXPY            10796 1.0 1.1721e-01 1.4 3.23e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0 16  0  0  0   1 16  0  0  0 3092074
VecAYPX             5397 1.0 5.4340e-02 1.4 1.61e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0  8  0  0  0   0  8  0  0  0 3334231
VecScatterBegin     5398 1.0 5.4152e-02 3.3 0.00e+00 0.0 3.6e+07 6.9e+02 0.0e+00  0  0100100  0   0  0100100  0     0
VecScatterEnd       5398 1.0 8.6881e+00489.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   6  0  0  0  0     0
KSPSolve               1 1.0 1.7389e+01 1.0 2.02e+09 1.1 3.6e+07 6.9e+02 1.6e+04 29100100100100 100100100100100 130242
Gropp pipeline
MatMult             5399 1.0 9.5593e+0011.7 1.05e+09 1.1 3.6e+07 6.9e+02 0.0e+00  3 45100100  0   7 45100100  0 123207
VecNorm                1 1.0 8.8549e-0417.4 2.99e+04 1.1 0.0e+00 0.0e+00 1.0e+00  0  0  0  0  4   0  0  0  0 20 37912
VecAXPY            16194 1.0 1.6522e-01 1.4 4.84e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0 21  0  0  0   0 21  0  0  0 3290407
VecAYPX            10794 1.0 1.9903e-01 1.5 3.23e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0 14  0  0  0   1 14  0  0  0 1820606
VecScatterBegin     5399 1.0 6.2281e-02 3.6 0.00e+00 0.0 3.6e+07 6.9e+02 0.0e+00  0  0100100  0   0  0100100  0     0
VecScatterEnd       5399 1.0 8.7194e+00380.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   4  0  0  0  0     0
VecReduceArith     16195 1.0 2.2674e-01 3.7 4.84e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0 21  0  0  0   0 21  0  0  0 2397678
VecReduceBegin     10797 1.0 3.4089e-02 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecReduceEnd       10797 1.0 2.6197e+01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 37  0  0  0  0  91  0  0  0  0     0
SFBcastOpBegin      5399 1.0 6.0051e-02 4.1 0.00e+00 0.0 3.6e+07 6.9e+02 0.0e+00  0  0100100  0   0  0100100  0     0
SFBcastOpEnd        5399 1.0 8.7167e+00440.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   4  0  0  0  0     0
KSPSolve               1 1.0 2.7477e+01 1.0 2.34e+09 1.1 3.6e+07 6.9e+02 1.0e+00 41100100100  4 100100100100 20 95623
pipeline cg
MatMult             5400 1.0 1.5915e+00 1.8 1.05e+09 1.1 3.6e+07 6.9e+02 0.0e+00  2 37100100  0   6 37100100  0 740161
VecAXPY            21592 1.0 2.3194e-01 1.4 6.45e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0 23  0  0  0   1 23  0  0  0 3125164
VecAYPX            21588 1.0 5.5059e-01 1.7 6.45e+08 1.1 0.0e+00 0.0e+00 0.0e+00  1 23  0  0  0   2 23  0  0  0 1316272
VecScatterBegin     5400 1.0 7.0132e-02 3.7 0.00e+00 0.0 3.6e+07 6.9e+02 0.0e+00  0  0100100  0   0  0100100  0     0
VecScatterEnd       5400 1.0 6.5329e-0122.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecReduceArith     16197 1.0 3.1135e-01 4.7 4.84e+08 1.1 0.0e+00 0.0e+00 0.0e+00  0 17  0  0  0   1 17  0  0  0 1746339
VecReduceBegin      5400 1.0 3.1471e-02 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecReduceEnd        5400 1.0 1.7226e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 28  0  0  0  0  90  0  0  0  0     0
SFBcastOpBegin      5400 1.0 6.6228e-02 4.1 0.00e+00 0.0 3.6e+07 6.9e+02 0.0e+00  0  0100100  0   0  0100100  0     0
SFBcastOpEnd        5400 1.0 6.5000e-0124.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
KSPSolve               1 1.0 1.8893e+01 1.0 2.82e+09 1.1 3.6e+07 6.9e+02 0.0e+00 32100100100  0 100100100100  0 167860
With pipelined methods the TDot and Vec norm are replaced with VecReduceArith, VecReduceBegin, and VecReduceEnd. The important numbers are
the %T in the stage.
In particular look at VecTDot and VecNorm and compare to VecReduceEnd in the pipeline methods. Note that both pipelined methods, especially the gropp method spend an enormous time in VecReduceEnd and hence end up taking more time than the non-pipelined method. So basically any advantage the pipeline methods may have is lost waiting for the previous reduction operation to arrive. I do not know why, if it is the MPI implementation or something else.
If you are serious about understanding pipeline methods for Krylov methods you will need to dig deep into the details of the machine hardware and MPI software. It is not a trivial subject with easy answers. I would say that the PETSc community are not experts on the topic, you will need to read in detail the publications on pipelined methods and consult with the authors on technical, machine specific details. There is a difference between the academic "pipelining as a theoretical construct"  and actually dramatic improvement on real machines while using pipelining. One small implementation detail can dramatically change performance so theoretical papers alone are not the complete story.
  Barry
On Feb 17, 2021, at 10:31 PM, 赵刚 <zhaog6 at lsec.cc.ac.cn> wrote:
Dear Barry,
Thank you. For MPI, MVAPICH-2.3.5 is used on my cluster by default, I add PetscLogStagePush("Calling KSPSolve()...") and PetscLogStagePop(). I am using other numerical software and have called PETSc only when solving linear system through PETSc interface supported by the software, but I'm not sure if I have added it correctly. I put the result and info into attachment, please check it.
Gang
-----原始邮件-----
发送时间:2021-02-18 10:52:11 (星期四)
  First please see https://www.mcs.anl.gov/petsc/documentation/faq.html#pipelined and verify that the MPI you are using satisfies the requirements and you have appropriate MPI environmental variables set (if needed).
  Then please add a stage around the actual computation to get a more useful summary.
  Organize your code like so
  KSPSetUp()
  PetscLogStagePush(a stage you created)
  KSPSolve()
  PetscLogStagePop()
  It is unclear where much of the time of your code is being spent, by adding the stage we'll have a clear picture of the time in the actual solver. There are examples of using PetscLogStagePush() in the source.
  With the new -log_view files you generate with these two changes we can get a handle on where the time is being spent and why the pipelining is or is not helping.
  Barry
On Feb 17, 2021, at 8:31 PM, 赵刚 <zhaog6 at lsec.cc.ac.cn> wrote:
Dear Barry,
Thank you for your prompt reply. I run ~16M DOFs on 32 nodes (36 cores per node), but CG seems to be faster than pipelined CG and Gropp's CG, I'm puzzled and haven't figured out why. Put the performance output into attachment, please check it.
Gang
> -----原始邮件-----
> 发件人: "Barry Smith" <bsmith at petsc.dev>
> 发送时间: 2021-02-18 09:17:17 (星期四)
> > On Feb 17, 2021, at 6:47 PM, 赵刚 <zhaog6 at lsec.cc.ac.cn> wrote:
> > Dear PETSc team,
> > I am interested in pipelined CG (-ksp_type pipecg) and Gropp's CG (-ksp_type groppcg), it is expected that this iterative method with pipelined has advantages over traditional CG in the case of multiple processes. So I'd like to ask for Poisson problem, how many computing nodes do I need to show the advantages of pipelined CG or Gropp's CG over CG (No preconditioner is used)?
> > Currently, I can only use up to 32 nodes (36 cores per nodes) at most on my cluster, but both "pipecg" and "groppcg" seem to be no advantage over "cg" when I solve Poisson equations with homogeneous Dirichlet BC in [0, 1]^2 (remain 20K~60K DOFs per process). I guess the reason would be too few computing nodes.
>   900 cores (assuming they are not memory bandwidth bound) might be enough to see some differences but the differences are likely so small compared to other parallel issues that affect performance that you see no consistently measurable difference.
>    Run with -log_view three cases, no pipeline and the two pipelines and send the output. By studying where the time is spent in the different regions of the code with this output one may be able to say something about the pipeline affect.
>   Barry
> > Because I am calling PETSc via other numerical software, if need, I would mail related performance information to you by using command line options suggested by PETSc. Thank you.
> > Thanks,
> > Gang
</zhaog6 at lsec.cc.ac.cn></petsc-users at mcs.anl.gov></zhaog6 at lsec.cc.ac.cn></bsmith at petsc.dev><cg.out><groppcg.out><pipecg.out>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210218/d8e8557d/attachment-0001.html>
