[petsc-users] Explicit linking to OpenMP results in performance drop and wrong results
Matthew Knepley
knepley at gmail.com
Wed Feb 17 11:51:43 CST 2021
Jed, is it possible that this is an oversubscription penalty from bad
OpenMP settings? <said by a person who knows less about OpenMP than
cuneiform>
Matt
On Wed, Feb 17, 2021 at 12:11 PM Roland Richter <roland.richter at ntnu.no>
wrote:
> My PetscScalar is complex double (i.e. even higher penalty), but my matrix
> has a size of 8kk elements, so that should not an issue.
> Regards,
> Roland
> *Von:* Jed Brown <jed at jedbrown.org>
> *Gesendet:* Mittwoch, 17. Februar 2021 17:49:49
> *An:* Roland Richter; PETSc
> *Betreff:* Re: [petsc-users] Explicit linking to OpenMP results in
> Roland Richter <roland.richter at ntnu.no> writes:
> > Hei,
> > I replaced the linking line with
> > //usr/lib64/mpi/gcc/openmpi3/bin/mpicxx -march=native -fopenmp-simd
> > -DMKL_LP64 -m64
> > CMakeFiles/armadillo_with_PETSc.dir/Unity/unity_0_cxx.cxx.o -o
> > bin/armadillo_with_PETSc
> > -Wl,-rpath,/opt/boost/lib:/opt/fftw3/lib64:/opt/petsc_release/lib
> > /usr/lib64/libgsl.so /usr/lib64/libgslcblas.so -lgfortran
> > -L${MKLROOT}/lib/intel64 -Wl,--no-as-needed -lmkl_intel_lp64
> > -lmkl_gnu_thread -lmkl_core -lgomp -lpthread -lm -ldl
> > /opt/boost/lib/libboost_filesystem.so.1.72.0
> > /opt/boost/lib/libboost_mpi.so.1.72.0
> > /opt/boost/lib/libboost_program_options.so.1.72.0
> > /opt/boost/lib/libboost_serialization.so.1.72.0
> > /opt/fftw3/lib64/libfftw3.so /opt/fftw3/lib64/libfftw3_mpi.so
> > /opt/petsc_release/lib/libpetsc.so
> > /usr/lib64/gcc/x86_64-suse-linux/9/libgomp.so
> > and now the results are correct. Nevertheless, when comparing the loop
> > in line 26-28 in file test_scaling.cpp
> > /#pragma omp parallel for//
> > // for(int i = 0; i < r_0 * r_1; ++i)//
> > // *(out_mat_ptr + i) = (*(in_mat_ptr + i) * scaling_factor);/
> > the version without /#pragma omp parallel/ for is significantly faster
> > (i.e. 18 s vs 28 s) compared to the version with /omp./ Why is there
> > still such a big difference?
> Sounds like you're using a profile to attribute time? Each `omp parallel`
> region incurs a cost ranging from about a microsecond to 10 or more
> microseconds depending on architecture, number of threads, and OpenMP
> implementation. Your loop (for double precision) operates at around 8
> entries per clock cycle (depending on architecture) if the operands are in
> cache so the loop size r_0 * r_1 should be at least 10000 just to pay off
> the cost of `omp parallel`.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210217/d37b2a2b/attachment.html>
