[petsc-users] makefile for building application with petsc
Swarnava Ghosh swarnava89 at gmail.com
Tue Feb 16 18:31:13 CST 2021
Thank you for your responses. The CXXPPFLAGS as mentioned by Satish makes
it work.
Sincerely,
Swarnava
On Tue, Feb 16, 2021 at 1:07 PM Satish Balay via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> BTW: Here is a simple makefile for multiple sources.
> balay at sb /home/balay/tmp/prj/src
> $ ls
> main.cxx  makefile  sub.cxx
> $ ls ../inc/
> mainc.h
> $ cat makefile
> all: main
> CXXPPFLAGS       = -I../inc
> LDLIBS           = -lmv
> include ${PETSC_DIR}/lib/petsc/conf/variables
> include ${PETSC_DIR}/lib/petsc/conf/rules
> include ${PETSC_DIR}/lib/petsc/conf/test
> main: sub.o
> We don't have a simple makefile for the use case where src, obj, binaries
> are  in different locations.
> gmakefile.test has some code for it [this requires replacing
> 'lib/petsc/conf/test' with custom compile targets - as in gmakefile.test].
> [and what you have appears to work for this usecase.]
> Satish
> On Tue, 16 Feb 2021, Satish Balay via petsc-users wrote:
> > for CXX - its CXXPPFLAGS
> > > >> > CPPFLAGS = -I ./inc -I ${MKLROOT}/include -L ${MKLROOT}/lib/
> > > >> -llapack-addons -lmkl_intel_lp64 -lmkl_sequential -lmkl_core
> -lpthread
> > The link options shouldn't go into preprocessor flags.
> > Also duplicate blas with petsc might cause grief. Best to build petsc
> with mkl.
> > Satish
> > On Tue, 16 Feb 2021, Matthew Knepley wrote:
> > > On Tue, Feb 16, 2021 at 9:39 AM Jacob Faibussowitsch <
> jacob.fai at gmail.com>
> > > wrote:
> > > > Swarnava,
> > > > Perhaps try CXXFLAGS instead of CPPFLAGS. Alternatively, you may
> > > > explicitly declare a %.o: %.cc target and force it to include your
> CPPFLAGS.
> > > No, do not do either of these things. We just need to figure out why
> it is
> > > not working for you. I will make a small example as soon as possible.
> > >   Thanks,
> > >      Matt
> > > > Best regards,
> > > > (Jacob Fai - booss - oh - vitch)
> > > > Cell: (312) 694-3391
> > > > On Feb 16, 2021, at 08:42, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > > On Mon, Feb 15, 2021 at 10:50 PM Barry Smith <bsmith at petsc.dev>
> wrote:
> > > >> Swarnava,
> > > >> sddft.h is not a PETSc include file, nor is it used by PETSc so I
> think
> > > >> the issue is not directly to PETSc it is related to where sddft is
> on the
> > > >> machine and how it is found by your makefile.
> > > > Barry,
> > > > His problem is that he is trying to put extra include flags on the
> compile
> > > > line, but it is not working. I am wondering if his make is
> malfunctioning.
> > > >   Thanks,
> > > >      Matt
> > > >>   Barry
> > > >> > On Feb 15, 2021, at 7:47 PM, Swarnava Ghosh <swarnava89 at gmail.com
> > > >> wrote:
> > > >> > Dear Petsc developers and users,
> > > >> > I am having some issue with building my code with the following
> > > >> makefile. I was earlier able to build this with the same makefile
> on a
> > > >> different machine. Would you please help me out on this issue?
> > > >> > Contents of makefile:
> > > >> > all:sparc
> -lpthread
> > > >> > SOURCECPP = ./src/main.cc ./src/initObjs.cc ./src/readfiles.cc
> ./src/
> > > >> energy.cc ./src/ExchangeCorrelation.cc ./src/occupation.cc ./src/
> > > >> poisson.cc ./src/chebyshev.cc ./src/scf.cc ./src/mixing.cc ./src/
> > > >> forces.cc ./src/relaxatoms.cc ./src/multipole.cc
> ./src/electrostatics.cc
> > > >> ./src/tools.cc
> > > >> > SOURCEH = ./inc/sddft.h ./inc/isddft.h
> > > >> > OBJSC = ./src/main.o ./src/initObjs.o ./src/readfiles.o
> ./src/energy.o
> > > >> ./src/ExchangeCorrelation.o ./src/occupation.o ./src/poisson.o
> > > >> ./src/chebyshev.o ./src/scf.o ./src/mixing.o ./src/forces.o
> > > >> ./src/relaxatoms.o ./src/multipole.o ./src/electrostatics.o
> ./src/tools.o
> > > >> > LIBBASE = ./lib/sparc
> > > >> > CLEANFILES = ./lib/sparc
> > > >> > sparc: ${OBJSC} chkopts
> > > >> > ${CLINKER} -Wall -o ${LIBBASE} ${OBJSC} ${PETSC_LIB}
> > > >> > ${RM} $(SOURCECPP:%.cc=%.o)
> > > >> > Error:
> > > >> > /home/swarnava/petsc/linux-gnu-intel/bin/mpicxx -o src/main.o -c
> -g
> > > >>  -I/home/swarnava/petsc/include
> > > >> -I/home/swarnava/petsc/linux-gnu-intel/include    `pwd`/src/main.cc
> > > >> > /home/swarnava/Research/Codes/SPARC/src/main.cc(24): catastrophic
> > > >> error: cannot open source file "sddft.h"
> > > >> >   #include "sddft.h"
> > > >> > It's not able to see the header file though I have -I ./inc in
> > > >> CPPFLAGS. The directory containing makefile has the directory "inc"
> with
> > > >> the headers and "src" with the .cc files.
> > > >> > Thank you,
> > > >> > Swarnava
> > > > What most experimenters take for granted before they begin their
> > > > experiments is infinitely more interesting than any results to which
> their
> > > > experiments lead.
> > > > -- Norbert Wiener
> > > > https://www.cse.buffalo.edu/~knepley/
> > > > <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210216/f4cc0d92/attachment-0001.html>
