[petsc-users] shell preconditioner for Schur complement
Matteo Semplice
matteo.semplice at uninsubria.it
Thu Feb 11 09:52:31 CST 2021
Il 11/02/21 06:41, Barry Smith ha scritto:
> Best to just look at the code to see exactly what it is doing: src/ksp/pc/impls/fieldsplit/fieldsplit.c function PCApply_FieldSplit_Schur()
> There is no particular "scaling" applied to the vectors. It might be easiest to track through the computational process with the debugger (you can call VecView(v,0) in the debugger anytime to see the current vector) to see why the "scaling" seems to change.
> Barry
Found!
It came from the initial rescaling b->b/norm(b) in the fgmres for the
entire matrix.
We are now set and we can concentrate on our routine.
Thanks a lot Matthew and Barry!
Matteo & Elena
Prof. Matteo Semplice
Università degli Studi dell’Insubria
Dipartimento di Scienza e Alta Tecnologia – DiSAT
Professore Associato
Via Valleggio, 11 – 22100 Como (CO) – Italia
tel.: +39 031 2386316
