[petsc-users] Using parmetis from petsc
Wed Feb 10 09:06:02 CST 2021
On Wed, Feb 10, 2021 at 10:00 AM Edoardo alinovi <edoardo.alinovi at gmail.com>
wrote:
> Thanks Matthew,
> Probably in my case is a good idea to use parmetis directly as i just need
> the cell distribution in pre-procrssing. Thanks for the clarification.
> On an affine side, it's a while i am interrogating my self about a thing.
> Let's say i have my cell distribution accross processors from parmetis.
> Since petsc needs to have the unknows from 1 to N0 hosted by rank 0,
> N0+1:N2 hosted by rank 2 and so on, what i am doing is relabelling local
> cells in order to meet this requirement . Is that right? I am wondering if
> such a way of things is leading to a suboptimal matrix bandwith. What do
> you think about this?
I do not understand. If parmetis gives you a partition, you would have to
move the data to match the new partition.
    Matt
> Many thanks,
> Edoardo
> On Wed, 10 Feb 2021, 13:12 Matthew Knepley, <knepley at gmail.com> wrote:
>> On Wed, Feb 10, 2021 at 4:07 AM Edoardo alinovi <
>> edoardo.alinovi at gmail.com> wrote:
>>> Hello PETSc friends,
>>> I am working on a code to partition a mesh in parallel and I am looking
>>> at parmetis. As far as I know petsc is interfaced with metis and parmetis
>>> and I have seen people using it within dmplex. Now, I am not using dmplex,
>>> but  I have petsc compiled along with my code for the linear system part.
>>> I am wondering if there is a way to load up a mesh file in the parmetis
>>> format and use petsc to get the elements partitioning only in output. Is
>>> that possible?
>> ParMetis does not really have a mesh format. It partitions distributed
>> graphs. Most people want to partition cells in their mesh, and
>> then ParMetis would want the graph for cell connectivity. This is not
>> usually what people store, so typically there is a conversion process
>> here. If you want to use PETSc for partitioning, and not use DMPlex, the
>> easiest way to do it is to put your cell connectivity in a Mat,
>> storing the adjacency graph for cells. Then use MatPartitioning.
>>  Thanks,
>>      Matt
>>> Thank you for the help,
>>> Edoardo
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210210/53c939ff/attachment-0001.html>
