[petsc-users] DMPlex tetrahedra facets orientation
Matthew Knepley
knepley at gmail.com
Mon Feb 8 08:19:06 CST 2021
On Mon, Feb 8, 2021 at 6:01 AM Nicolas Barral <
nicolas.barral at math.u-bordeaux.fr> wrote:
> Hi all,
> Can I make any assumption on the orientation of triangular facets in a
> tetrahedral plex ? I need the inward facet normals. Do I need to use
> DMPlexGetOrientedFace or can I rely on either the tet vertices ordering,
> or the faces ordering ? Could DMPlexGetRawFaces_Internal be enough ?
You can do it by hand, but you have to account for the face orientation
relative to the cell. That is what
DMPlexGetOrientedFace() does. I think it would be easier to use the
function below.
> Alternatively, is there a function that computes the normals - without
> bringing out the big guns ?
This will compute the normals
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexComputeCellGeometryFVM.html
Should not be too heavy weight.
THanks,
Matt
Thanks
> Nicolas
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210208/4723f1e2/attachment.html>
