[petsc-users] Fortran initialization and XXXDestroy
Mark Adams mfadams at lbl.gov
Wed Feb 3 06:07:44 CST 2021
Perhaps a custom Fortran interface that checks for FORTRAN_TYPE_INITIALIZE.
That was the first thing that I looked for.
On Tue, Feb 2, 2021 at 11:31 PM Satish Balay <balay at mcs.anl.gov> wrote:
> I think the current code is to support:
> if (var not initialized): crate(var).
> And there might be some mapping of 0 to NULL or some other state (hence
> the choice of -2)
> Satish
> On Tue, 2 Feb 2021, Barry Smith wrote:
> >   I cannot remember why I selected -2 as the initial value for PETSc
> objects in Fortran. Probably because it would ensure a dramatic crash if
> you used
> > an object without initializing it from Fortran.
> >   It could be changing
> > config/BuildSystem/config/compilersFortran.py:
> self.addDefine('FORTRAN_TYPE_INITIALIZE', ' = -2')
> > to 0 would mean that if you called destroy on the object and never
> created it everything would be fine; so you would not need to use any
> special code to check.
> > Would that be a better model?
> >   Barry
> > > On Feb 2, 2021, at 2:34 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > Thanks Randy, that makes sense.
> > > Mark
> > > On Tue, Feb 2, 2021 at 3:27 PM Randall Mackie <rlmackie862 at gmail.com
> <mailto:rlmackie862 at gmail.com>> wrote:
> > > Hi Mark,
> > > I don’t know what the XGC code is, but the way I do this in my Fortran
> code is that I initialize all objects I later want to destroy, for example:
> > > mat11=PETSC_NULL_MAT
> > > vec1=PETSC_NULL_VEC
> > > etc
> > > Then I check and destroy like:
> > > if (mat11 /= PETSC_NULL_MAT) call MatDestroy(mat11, ierr)
> > > etc.
> > > Hope this helps,
> > > Randy
> > > > On Feb 2, 2021, at 12:17 PM, Mark Adams <mfadams at lbl.gov <mailto:
> mfadams at lbl.gov>> wrote:
> > > > Satish, a few years ago you helped us transition the XGC Fortran
> code from v3.7.7 and we seemed to have regressed.
> > > > As I recall we removed the initialization of Mats (for example) in
> XGC. PETSc seems to initialize them with -2 in Fortran (Albert, cc'ed,
> verified this today) and I recall that from our previous conversation. As I
> look at the code now Fortran MatDestroy just goes straight to C, which
> would explain our crashes when we MatDestroy an uninitialized (-2) Mat.
> > > > What is the correct way to delete with initializing Fortran objects?
> > > > Thanks,
> > > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210203/14c32e7e/attachment.html>
