[petsc-users] Fortran initialization and XXXDestroy
Barry Smith
bsmith at petsc.dev
Tue Feb 2 20:37:00 CST 2021
I cannot remember why I selected -2 as the initial value for PETSc objects in Fortran. Probably because it would ensure a dramatic crash if you used
an object without initializing it from Fortran.
It could be changing
config/BuildSystem/config/compilersFortran.py: self.addDefine('FORTRAN_TYPE_INITIALIZE', ' = -2')
to 0 would mean that if you called destroy on the object and never created it everything would be fine; so you would not need to use any special code to check.
Would that be a better model?
Barry
> On Feb 2, 2021, at 2:34 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Thanks Randy, that makes sense.
> Mark
> On Tue, Feb 2, 2021 at 3:27 PM Randall Mackie <rlmackie862 at gmail.com <mailto:rlmackie862 at gmail.com>> wrote:
> Hi Mark,
> I don’t know what the XGC code is, but the way I do this in my Fortran code is that I initialize all objects I later want to destroy, for example:
> mat11=PETSC_NULL_MAT
> vec1=PETSC_NULL_VEC
> etc
> Then I check and destroy like:
> if (mat11 /= PETSC_NULL_MAT) call MatDestroy(mat11, ierr)
> etc.
> Hope this helps,
> Randy
> > On Feb 2, 2021, at 12:17 PM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> > Satish, a few years ago you helped us transition the XGC Fortran code from v3.7.7 and we seemed to have regressed.
> > As I recall we removed the initialization of Mats (for example) in XGC. PETSc seems to initialize them with -2 in Fortran (Albert, cc'ed, verified this today) and I recall that from our previous conversation. As I look at the code now Fortran MatDestroy just goes straight to C, which would explain our crashes when we MatDestroy an uninitialized (-2) Mat.
> > What is the correct way to delete with initializing Fortran objects?
> > Thanks,
> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210202/b280d880/attachment.html>
