[petsc-users] Combining SUPERLU_DIST with CUDA fails
Roland Richter
roland.richter at ntnu.no
Mon Dec 20 13:59:41 CST 2021
I introduced the changes from that patch directly, without checking out.
Is that insufficient?
Roland
Am 20.12.2021 um 20:38 schrieb Barry Smith:
> Are you sure you have the correct PETSc branch? From configure.log
> it has
> Defined "VERSION_GIT" to ""v3.16.2-466-g959e1fce86""
> Defined "VERSION_DATE_GIT" to ""2021-12-18 11:17:24 -0600""
> Defined "VERSION_BRANCH_GIT" to ""master""
> It should have balay/slu-without-omp-3 for the branch.
>> On Dec 20, 2021, at 10:50 AM, Roland Richter <roland.richter at ntnu.no>
>> wrote:
>> In that case it fails with
>> /~/Downloads/git-files/petsc/mpich-complex-linux-gcc-demo/externalpackages/git.superlu_dist/SRC/cublas_utils.h:22:10:
>> fatal error: cublas_v2.h: No such file or directory/
>> even though this header is available. I assume some header paths are
>> not set correctly?
>> Thanks,
>> regards,
>> Roland
>> Am 20.12.21 um 16:29 schrieb Barry Smith:
>>> Please try the branch balay/slu-without-omp-3 It is in MR
>>> https://gitlab.com/petsc/petsc/-/merge_requests/4635
>>>> On Dec 20, 2021, at 8:14 AM, Roland Richter
>>>> <roland.richter at ntnu.no> wrote:
>>>> Hei,
>>>> I tried to combine CUDA with superlu_dist in petsc using the
>>>> following configure-line:
>>>> /./configure PETSC_ARCH=mpich-complex-linux-gcc-demo
>>>> --CC=/opt/intel/oneapi/mpi/2021.5.0/bin/mpicc
>>>> --CXX=/opt/intel/oneapi/mpi/2021.5.0/bin/mpicxx
>>>> --FC=/opt/intel/oneapi/mpi/2021.5.0/bin/mpifc --CFLAGS="-mavx2
>>>> -march=native -O3" --CXXFLAGS="-mavx2 -march=native -O3"
>>>> --FFLAGS="-mavx2 -march=native -O3"
>>>> --CUDAFLAGS=-allow-unsupported-compiler --CUDA-CXX=g++
>>>> --prefix=/opt/petsc --with-blaslapack=1 --with-mpi=1
>>>> --with-scalar-type=complex --download-suitesparse=1 --with-cuda
>>>> --with-debugging=0 --with-openmp --download-superlu_dist --force/
>>>> but the configure-step fails with several errors correlated with
>>>> CUDA and superlu_dist, the first one being
>>>> /cublas_utils.c:21:37: error: ‘CUDART_VERSION’ undeclared (first
>>>> use in this function); did you mean ‘CUDA_VERSION’?//
>>>> // 21 | printf("CUDA version: v %d\n",CUDART_VERSION);//
>>>> //| CUDA_VERSION/
>>>> Compiling superlu_dist separately works, though (including CUDA).
>>>> Is there a bug somewhere in the configure-routine? I attached the
>>>> full configure-log.
>>>> Thanks!
>>>> Regards,
>>>> Roland
>>>> <configure.log>
>> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211220/7c7cc660/attachment.html>
