[petsc-users] NVIDIA HPC SDK and complex data type
Junchao Zhang
junchao.zhang at gmail.com
Sun Dec 19 17:38:16 CST 2021
Since it will take a while for NVIDIA to fix the bug in their NVCHPC 21.11
(December 2021), I added a workaround to the MR in petsc,
https://gitlab.com/petsc/petsc/-/merge_requests/4663
I tested it and it works with debugging (-O0) or no debugging (-O, or
-O2).
--Junchao Zhang
On Sat, Dec 18, 2021 at 7:51 PM Barry Smith <bsmith at petsc.dev> wrote:
> Yes, Junchao deserves a bounty from NVIDIA for this find.
> On Dec 18, 2021, at 8:22 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Dec 18, 2021 at 7:03 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> I found it is a NVIDIA C/C++ compiler bug. I can reproduce it with
> Great find!
> Matt
>> #include <stdlib.h>
>> #include <stdio.h>
>> #include <complex.h>
>> typedef double _Complex PetscScalar;
>> typedef struct {
>> int row;
>> PetscScalar *valaddr;
>> } MatEntry2;
>> int main(int arc, char** argv)
>> int i=2;
>> MatEntry2 *Jentry2 = (MatEntry2*)malloc(64*sizeof(MatEntry2));
>> PetscScalar a=1, b=1;
>> printf("sizeof(MatEntry2)=%lu\n",sizeof(MatEntry2));
>> Jentry2[2].valaddr = (PetscScalar*)malloc(16*sizeof(PetscScalar));
>> *(Jentry2[i].valaddr) = a*b; // Segfault
>> free(Jentry2[2].valaddr);
>> free(Jentry2);
>> return 0;
>> $ nvc -O0 -o test test.c
>> $ ./test
>> sizeof(MatEntry2)=16
>> Segmentation fault (core dumped)
>> If I change *(Jentry2[i].valaddr) = a*b; to
>> PetscScalar *p = Jentry2[2].valaddr;
>> *p = a*b;
>> Then the code works fine. Using -O0 to -O2 will also avoid this error
>> for this simple test, but not for PETSc. In PETSc, I could apply the above
>> silly trick, but I am not sure it is worth it. We should instead report it
>> to NVIDIA.
>> Looking at the assembly code for the segfault line, we can find the
>> problem
>> movslq 52(%rsp), %rcx
>> movq 40(%rsp), %rax
>> movq 8(%rax,%rcx,8), %rax // Here %rax = &Jentry2, %rcx = i; The
>> instruction wrongly calculates Jentry2[2].valaddr as (%rax +
>> %rcx*8)+8, which should instead be (%rax + %rcx*16)+8
>> vmovsd %xmm1, 8(%rax)
>> vmovsd %xmm0, (%rax)
>> --Junchao Zhang
>> On Fri, Dec 17, 2021 at 7:58 PM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> Hi, Jon,
>>> I could reproduce the error exactly. I will have a look.
>>> Thanks for reporting.
>>> --Junchao Zhang
>>> On Fri, Dec 17, 2021 at 2:56 PM Jonathan D. Halverson <
>>> halverson at princeton.edu> wrote:
>>>> Hello,
>>>> We are unable to build PETSc using the NVIDIA HPC SDK and
>>>> --with-scalar-type=complex. Below is our procedure:
>>>> $ module load nvhpc/21.11
>>>> $ module load openmpi/nvhpc-21.11/4.1.2/64
>>>> $ git clone -b release https://gitlab.com/petsc/petsc.git petsc; cd
>>>> petsc
>>>> $ ./configure --with-debugging=1 --with-scalar-type=complex
>>>> PETSC_ARCH=openmpi-power
>>>> $ make PETSC_DIR=/home/$USER/software/petsc PETSC_ARCH=openmpi-power all
>>>> check
>>>> "make check" fails with a segmentation fault when running ex19. The
>>>> fortran test ex5f passes.
>>>> The procedure above fails on x86_64 and POWER both running RHEL8. It
>>>> also fails using nvhpc 20.7.
>>>> The procedure above works for "real" instead of "complex".
>>>> A "hello world" MPI code using a complex data type works with our nvhpc
>>>> modules.
>>>> The procedure above works successfully when GCC and an Open MPI library
>>>> built using GCC is used.
>>>> The only trouble is the combination of PETSc with nvhpc and complex.
>>>> Any known issues?
>>>> The build log for the procedure above is here:
>>>> https://tigress-web.princeton.edu/~jdh4/petsc_nvhpc_complex_17dec2021.log
>>>> Jon
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211219/fdb5291d/attachment.html>
