[petsc-users] --with-mpi=0
Tabrez Ali tabrezali at gmail.com
Fri Dec 17 18:16:26 CST 2021
I am trying to compile Fortran code with PETSc 3.16 built without MPI,
i.e., --with-mpi=0, and am getting the following error:
   call MPI_Comm_rank(MPI_COMM_WORLD,rank,ierr)
                                         1
Error: Symbol ‘mpi_comm_world’ at (1) has no IMPLICIT type
There are no issues with PETSc 3.14 or prior versions. Any ideas as to what
could be wrong?
I do see the following note (below) in
https://petsc.org/main/docs/changes/315/ but I am not sure if it's related:
*Add configure option --with-mpi-f90module-visibility [default=``1``].
With 0, mpi.mod will not be visible in use code (via petscsys.mod) -
so mpi_f08 can now be used*
Tabrez
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211217/61ba75f9/attachment-0001.html>
