[petsc-users] PCs and MATIS
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Tue Dec 14 21:30:24 CST 2021
Hi Pierre,
ok, that's a nice trick!
Thanks for this great hint! :)
Eric
On 2021-12-14 3:58 p.m., Pierre Jolivet wrote:
> Hello Eric,
> Why do you want to use a MATIS?
> This solution that Barry suggested to me some time ago is perfectly
> functioning:
> https://lists.mcs.anl.gov/pipermail/petsc-dev/2020-January/025491.html
> <https://lists.mcs.anl.gov/pipermail/petsc-dev/2020-January/025491.html>
> That’s what I do for optimized (restricted) additive Schwarz.
> You can see also how to use this “trick” from Barry here:
> https://gitlab.com/petsc/petsc/-/commit/ba409789b0c94205af794ad85bdac232504f2b3f#2c7d367ac831f3b0c5fb767c0eb16c1ea7ae7fe0_821_821
> <https://gitlab.com/petsc/petsc/-/commit/ba409789b0c94205af794ad85bdac232504f2b3f#2c7d367ac831f3b0c5fb767c0eb16c1ea7ae7fe0_821_821> (it’s
> in a WIP branch, and for the fine-level PCASM smoother used in
> PCHPDDM, but at least it’s actual code, in case you do not follow what
> Barry and I are saying in the old thread).
> Thanks,
> Pierre
>> On 14 Dec 2021, at 9:37 PM, Eric Chamberland
>> <Eric.Chamberland at giref.ulaval.ca
>> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
>> Hi,
>> We want to use an Additive Schwarz preconditioner (like PCASM)
>> combined with overlapping meshes *and* specific boundary conditions
>> to local (MATIS) matrices.
>> At first sight, MATIS is only supported for BDDC and FETI-DP and is
>> not working with PCASM.
>> Do we have to write a new PC from scratch to combine the use of mesh
>> overlap, MATIS and customized local matrices?
>> ...or is there any working example we should look at to start from? :)
>> Thanks a lot!
>> Eric
>> Eric Chamberland, ing., M. Ing
>> Professionnel de recherche
>> GIREF/Université Laval
>> (418) 656-2131 poste 41 22 42
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211214/f99d5ded/attachment-0001.html>
