[petsc-users] Help initializing matrix to a constant
Rohan Yadav rohany at alumni.cmu.edu
Tue Dec 14 12:46:42 CST 2021
I'm having trouble setting all entries of a matrix to a constant value,
similar to the `VecSet` method on vectors. I have a dense matrix that I
want to initialize all entries to 1. The only related method I see on the
`Mat` interface is `MatZeroEntries`, which sets all entries to 0. The
obvious first attempt is to use the `MatSetValue` function to set all
entries to the constant.
  Mat C;
  MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE, k, j, NULL,
&C);
  for (int kk = 0; kk < k; kk++) {
    for (int jj = 0; jj < j; jj++) {
      MatSetValue(C, kk, jj, 1, INSERT_VALUES);
  MatAssemblyBegin(C, MAT_FINAL_ASSEMBLY);
  MatAssemblyEnd(C, MAT_FINAL_ASSEMBLY);
However, when run with a relatively large matrix C (5GB) and a
rank-per-core on my 40-core machine this code OOMs and crashes. It does not
OOM with only 1 and 10 rank, leading me to believe that this API call is
somehow causing the entire matrix to be replicated on each rank.
Despite looking through the documentation, I could not find another API
call that would allow me to set all the values in the matrix to a constant.
What should I do here?
Rohan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211214/f5961a85/attachment.html>
