[petsc-users] non-manifold DMPLEX
Patrick Sanan patrick.sanan at gmail.com
Mon Dec 13 01:34:58 CST 2021
This would be a particularly useful example for testing the PETSc library,
as most applications are set on manifolds. There’s a recently-reformatted
chapter in the developers docs on how the testing works - this explains the
/* TEST */ blocks you see. If parts of these docs are confusing, that’s
very useful feedback for us!
https://petsc.org/release/developers/testing
Matthew Knepley <knepley at gmail.com> schrieb am Mo. 13. Dez. 2021 um 03:12:
> On Sun, Dec 12, 2021 at 4:36 PM TARDIEU Nicolas <nicolas.tardieu at edf.fr>
> wrote:
>> Dear Patrick and Matthew,
>> Thank you very much for your answers. I am gonna try to set up such a
>> test by assigning cell types.
>> Shall I open a MR in order to contribute this example ?
> Yes, that would be great.
>   Thanks,
>     Matt
>> Regards,
>> Nicolas
>> *De :* knepley at gmail.com <knepley at gmail.com>
>> *Envoyé :* dimanche 12 décembre 2021 12:17
>> *À :* Patrick Sanan <patrick.sanan at gmail.com>
>> *Cc :* TARDIEU Nicolas <nicolas.tardieu at edf.fr>; petsc-users at mcs.anl.gov
>> <petsc-users at mcs.anl.gov>
>> *Objet :* Re: [petsc-users] non-manifold DMPLEX
>> On Sun, Dec 12, 2021 at 6:11 AM Patrick Sanan <patrick.sanan at gmail.com>
>> wrote:
>> Here you have the following "points":
>> - 1 3-cell (the cube volume)
>> - 7 2-cells (the 6 faces of the cube plus the extra one)
>> - 16 1-cells  (the 12 edges of the cube, plus 3 extra ones from the extra
>> face, plus the extra edge)
>> - 11 0-cells (the 8 vertices of the cube, pus 2 extra ones from the extra
>> face, plus the extra vertex)
>> You could encode your mesh as here, by directly specifying relationships
>> between these points in the Hasse diagram:
>> https://petsc.org/release/docs/manual/dmplex/#representing-unstructured-grids
>> <https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpetsc.org%2Frelease%2Fdocs%2Fmanual%2Fdmplex%2F%23representing-unstructured-grids&data=04%7C01%7Cnicolas.tardieu%40edf.fr%7Cb7faa53e924149df02bb08d9bd610c10%7Ce242425b70fc44dc9ddfc21e304e6c80%7C1%7C0%7C637749046784571371%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=NX0gPHyjCX3kU%2BZIAZwZQ4951FpJCdri36OzDfRoLbk%3D&reserved=0>
>> Then, maybe the special relation is captured because you've defined the
>> "cone" or "support" for each "point", which tells you about the local
>> topology everywhere. E.g. to take the simpler case, three of the faces have
>> the yellow edge in their "cone", or equivalently the yellow edge has those
>> three faces in its "support".
>> This is correct. I can help you make this if you want. I think if you
>> assign cell types, you can even get Plex to automatically interpolate.
>> Note that with this kind of mesh, algorithms which assume a uniform cell
>> dimension will break, but I am guessing you would not
>> be interested in those anyway.
>>   Thanks,
>>     Matt
>> Am Fr., 10. Dez. 2021 um 17:04 Uhr schrieb TARDIEU Nicolas via
>> petsc-users <petsc-users at mcs.anl.gov>:
>> Dear PETSc Team,
>> Following a previous discussion on the mailing list, I'd like to
>> experiment with DMPLEX with a very simple non-manifold mesh as shown in the
>> attached picture : a cube connected to a square by an edge and to an edge
>> by a point.
>> I have read some of the papers that Matthew et al. have written, but I
>> must admit that I do not see how to start...
>> I see how the define the different elements but I do not see how to
>> specify the special relationship between the cube and the square and
>> between the cube and the edge.
>> Once it will have been set correctly, what I am hoping is to be able to
>> use all the nice features of the DMPLEX object.
>> Best regards,
>> Nicolas
>> Ce message et toutes les pièces jointes (ci-après le 'Message') sont
>> établis à l'intention exclusive des destinataires et les informations qui y
>> figurent sont strictement confidentielles. Toute utilisation de ce Message
>> non conforme à sa destination, toute diffusion ou toute publication totale
>> ou partielle, est interdite sauf autorisation expresse.
>> Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de
>> le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou
>> partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de
>> votre système, ainsi que toutes ses copies, et de n'en garder aucune trace
>> sur quelque support que ce soit. Nous vous remercions également d'en
>> avertir immédiatement l'expéditeur par retour du message.
>> Il est impossible de garantir que les communications par messagerie
>> électronique arrivent en temps utile, sont sécurisées ou dénuées de toute
>> erreur ou virus.
>> ____________________________________________________
>> This message and any attachments (the 'Message') are intended solely for
>> the addressees. The information contained in this Message is confidential.
>> Any use of information contained in this Message not in accord with its
>> purpose, any dissemination or disclosure, either whole or partial, is
>> prohibited except formal approval.
>> If you are not the addressee, you may not copy, forward, disclose or use
>> any part of it. If you have received this message in error, please delete
>> it and all copies from your system and notify the sender immediately by
>> return message.
>> E-mail communication cannot be guaranteed to be timely secure, error or
>> virus-free.
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=04%7C01%7Cnicolas.tardieu%40edf.fr%7Cb7faa53e924149df02bb08d9bd610c10%7Ce242425b70fc44dc9ddfc21e304e6c80%7C1%7C0%7C637749046784571371%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=4MLthiWkfhugmu%2BQJ2%2BHxTUR8JbsgEZvlK1b7fUehvo%3D&reserved=0>
>> erreur ou virus.
>> return message.
>> virus-free.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211213/74490bdc/attachment.html>
