[petsc-users] SNES always ends at iteration 0
celestechevali at gmail.com celestechevali at gmail.com
Sun Dec 12 17:21:40 CST 2021
Hello,
I encountered a strange problem concerning the convergence of SNES.
In my recent test runs I found that SNES always stops at iteration 0...
At first I thought there may be an error with the tolerance setting, so I
output the tolerances :
*atol = 0.000000, rtol = 0.000000, stol = 0.000000, maxit = 50, maxf =
10000  Norm of error 760.491 Iterations 0*
Which are exactly the default values that I always used. However, for the
same tolerance settings, the SNES solver converges successfully if I
decrease the number of degrees of freedom in my system...
I wish to know if anyone has experienced the same type of problems or has
an idea about what could possibly cause the problem...
Thank you so much in advance.
I appreciate any advice that you provide.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211213/62558b58/attachment.html>
