[petsc-users] Unstructured mesh
Matthew Knepley
knepley at gmail.com
Fri Dec 10 20:26:51 CST 2021
On Fri, Dec 10, 2021 at 1:11 PM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Thank you that worked. I have attached the output of the run
> ./ex56 -cells 2,2,1 -max_conv_its 2 -lx 1. -alpha .01 -petscspace_degree 1
> -ksp_type cg -ksp_monitor -ksp_rtol 1.e-8 -pc_type asm -snes_monitor
> -use_mat_nearnullspace true -snes_rtol 1.e-10 -ex56_dm_view
> Below is the mesh information I get before the solve.
> Not sure how to interpret them – is ‘18’ say number of elements in certain
> direction?
0-cells are vertices, 1-cells are edges, etc, so this has 4 cubes. That is
why it has 18 vertices, 9 on top and 9 on the bottom. A
bunch of stuff is labeled on this mesh, but you don't have to worry about
it I think.
> How does ‘18’ come about – given cells 2,2,1 as input?
> Sorry, bit lost what markers and other labels represent.
> Mesh in 3 dimensions:
> 0-cells: 18
> 1-cells: 33
> 2-cells: 20
> 3-cells: 4
> Labels:
> marker: 1 strata with value/size (1 (48))
> Face Sets: 6 strata with value/size (6 (2), 5 (2), 3 (2), 4 (2), 1 (4),
> 2 (4))
> depth: 4 strata with value/size (0 (18), 1 (33), 2 (20), 3 (4))
> boundary: 1 strata with value/size (1 (66))
> celltype: 4 strata with value/size (7 (4), 0 (18), 4 (20), 1 (33))
> I am more puzzled as the mesh information changes after the solve?
Mark refined it once regularly, so each hexahedron is split into 8, giving
32 cubes.
Matt
> 0-cells: 75
> 1-cells: 170
> 2-cells: 128
> 3-cells: 32
> Labels:
> celltype: 4 strata with value/size (0 (75), 1 (170), 4 (128), 7 (32))
> depth: 4 strata with value/size (0 (75), 1 (170), 2 (128), 3 (32))
> marker: 1 strata with value/size (1 (240))
> Face Sets: 6 strata with value/size (6 (18), 5 (18), 3 (18), 4 (18), 1
> (36), 2 (36))
> boundary: 1 strata with value/size (1 (258))
> Best,
> Karthik.
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Friday, 10 December 2021 at 16:17
> *To: *"Chockalingam, Karthikeyan (STFC,DL,HC)" <
> *Cc: *"petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Unstructured mesh
> On Fri, Dec 10, 2021 at 10:49 AM Karthikeyan Chockalingam - STFC UKRI <
> Thank you for your response.
> I tried using the flag -dm_view to get mesh information.
> I was hoping it might create a output file with mesh information but it
> didn’t create any.
> What should I expect with -dm_view?
> -dm_view prints the Plex information to the screen (by default), but it
> responds to the normal viewer options.
> However, it looks like Mark changes the prefix on the mesh, so I think you
> need
> -ex56_dm_view
> Thanks,
> Matt
> Best,
> Karthik.
> *Date: *Friday, 10 December 2021 at 13:04
> On Fri, Dec 10, 2021 at 7:42 AM Karthikeyan Chockalingam - STFC UKRI <
> Hi Matt,
> I intend to perform a scaling study – I have a few more questions from ex56
> *3D, tri-quadratic hexahedra (Q1), displacement finite element
> formulation.*
> i) What makes the problem non-linear? I believe SNES
> are used to solve non-linear problems.
> It is a linear problem. We use SNES because it is easier to use it for
> everything.
> ii) 2,2,1 does it present the number of elements used
> in each direction?
> You can use -dm_view to show the mesh information actually used in the run.
> iii) What makes the problem unstructured? I believe the
> geometry is a cube or cuboid – is it because it uses DMPlex?
> Yes.
> iv) Do any external FEM package with an unstructured
> problem domain has to use DMPlex mat type?
> DMPlex is not a Mat type, but rather a DM type. I do not understand the
> question. For example, LibMesh uses PETSc solvers but has
> its own mesh types.
> v) What about -mat_type (not _dm_mat_type) ajicusparse
> – will it work with unstructured FEM discretised domains?
> dm_mat_type is just a way of setting the MatType that the DM creates. You
> can set it to whatever type you want. Since it uses MatSetValues()
> there may be overhead in converting to that matrix type, but it should
> work.
> I tried to run two problems of ex56 with two different domain size ( -
> attached you find the log_view outputs of both on *gpus*) using _pc_type
> asm:
> -use_mat_nearnullspace true -snes_rtol 1.e-10 > output_221.txt
> ./ex56 -cells 10,10,5 -max_conv_its 2 -lx 1. -alpha .01 -petscspace_degree
> 1 -ksp_type cg -ksp_monitor -ksp_rtol 1.e-8 -pc_type asm -snes_monitor
> Below is the SNES iteration for problem with 2,2,1 cells which converges
> after two non-linear iterations:
> 0 SNES Function norm 0.000000000000e+00
> 0 SNES Function norm 7.529825940191e+01
> 1 SNES Function norm 4.734810707002e-08
> 2 SNES Function norm 1.382827243108e-14
> Your KSP tolerance is too high, so it takes another iterate. Use -ksp_rtol
> 1e-10.
> Below is the SNES iteration for problem with 10,10,5 cells– why does it
> first decrease and then increase to *0 SNES Function norm
> 1.085975028558e+01* and finally converge?
> 0 SNES Function norm 2.892801019593e+01
> 1 SNES Function norm 5.361683383932e-07
> 2 SNES Function norm 1.726814199132e-14
> 0 SNES Function norm 1.085975028558e+01
> 1 SNES Function norm 2.294074693590e-07
> 2 SNES Function norm 2.491900236077e-14
> You are solving the problem twice, probably because ex56 is in its
> refinement loop.
> Thanks,
> Matt
> Kind regards,
> Karthik.
> *Date: *Thursday, 2 December 2021 at 10:57
> On Thu, Dec 2, 2021 at 3:33 AM Karthikeyan Chockalingam - STFC UKRI <
> Hello,
> Are there example tutorials on unstructured mesh in ksp? Can some of them
> run on gpus?
> There are many unstructured grid examples, e.g. SNES ex13, ex17, ex56. The
> solver can run on the GPU, but the vector/matrix
> FEM assembly does not. I am working on that now.
> Thanks,
> Matt
> Kind regards,
> Karthik.
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211210/52492fdf/attachment-0001.html>
