[petsc-users] Nullspaces
Matthew Knepley
knepley at gmail.com
Tue Dec 7 12:25:43 CST 2021
On Tue, Dec 7, 2021 at 11:19 AM Marco Cisternino <
marco.cisternino at optimad.it> wrote:
> Good morning,
> I’m still struggling with the Poisson equation with Neumann BCs.
> I discretize the equation by finite volume method and I divide every line
> of the linear system by the volume of the cell. I could avoid this
> division, but I’m trying to understand.
> My mesh is not uniform, i.e. cells have different volumes (it is an octree
> mesh).
> Moreover, in my computational domain there are 2 separated sub-domains.
> I build the null space and then I use MatNullSpaceTest to check it.
> If I do this:
> MatNullSpaceCreate(getCommunicator(), PETSC_TRUE, 0, nullptr, &nullspace);
> It works
This produces the normalized constant vector.
> If I do this:
> Vec nsp;
> VecDuplicate(m_rhs, &nsp);
> VecSet(nsp,1.0);
> VecNormalize(nsp, nullptr);
> MatNullSpaceCreate(getCommunicator(), PETSC_FALSE, 1, &nsp, &nullspace);
> It does not work
This is also the normalized constant vector.
So you are saying that these two vectors give different results with
MatNullSpaceTest()?
Something must be wrong in the code. Can you send a minimal example of
this? I will go
through and debug it.
Matt
> Probably, I have wrong expectations, but should not it be the same?
> Thanks
> Marco Cisternino, PhD
> ______________________
> Optimad Engineering Srl
> Via Bligny 5, Torino, Italia.
> +3901119719782
> www.optimad.it
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211207/7e78464e/attachment.html>
