[petsc-users] Nullspaces
Marco Cisternino marco.cisternino at optimad.it
Tue Dec 7 10:52:27 CST 2021
I’m sorry, I believed it was clear:
“it works” means MatNullSpaceTest returns true
“it does not work” means MatNullSpaceTest returns false
Is it enough?
Thanks
Marco Cisternino, PhD
marco.cisternino at optimad.it<mailto:marco.cisternino at optimad.it>
______________________
Optimad Engineering Srl
Via Bligny 5, Torino, Italia.
+3901119719782
www.optimad.it<http://www.optimad.it/>
Sent: martedì 7 dicembre 2021 17:47
To: Marco Cisternino <marco.cisternino at optimad.it>
Cc: petsc-users <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Nullspaces
Can you please give more details on what 'does not work' is.
More detail on how you judge what works would also be useful.
On Tue, Dec 7, 2021 at 11:19 AM Marco Cisternino <marco.cisternino at optimad.it<mailto:marco.cisternino at optimad.it>> wrote:
Good morning,
I’m still struggling with the Poisson equation with Neumann BCs.
I discretize the equation by finite volume method and I divide every line of the linear system by the volume of the cell. I could avoid this division, but I’m trying to understand.
My mesh is not uniform, i.e. cells have different volumes (it is an octree mesh).
Moreover, in my computational domain there are 2 separated sub-domains.
I build the null space and then I use MatNullSpaceTest to check it.
If I do this:
MatNullSpaceCreate(getCommunicator(), PETSC_TRUE, 0, nullptr, &nullspace);
It works
If I do this:
Vec nsp;
VecDuplicate(m_rhs, &nsp);
VecSet(nsp,1.0);
VecNormalize(nsp, nullptr);
MatNullSpaceCreate(getCommunicator(), PETSC_FALSE, 1, &nsp, &nullspace);
It does not work
Probably, I have wrong expectations, but should not it be the same?
Thanks
+3901119719782
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211207/9a063ad4/attachment.html>
