[petsc-users] install PETSc on windows
Tue Dec 7 09:31:10 CST 2021
Your build is with msmpi - but mpiexec from openmpi got used.
You can try compiling and running examples manually [with the correct mpiexec]
Satish
On Tue, 7 Dec 2021, liyuansen89 at gmail.com wrote:
> Hi Satish,
> I have another question. After I run the check command, I got the following
> output (the attached file), have I successfully installed the library? Is
> there any error?
> Thanks
> -----Original Message-----
> From: Satish Balay <balay at mcs.anl.gov>
> Sent: Monday, December 6, 2021 6:59 PM
> To: Ning Li <liyuansen89 at gmail.com>
> Cc: petsc-users <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] install PETSc on windows
> Glad it worked. Thanks for the update.
> Satish
> On Mon, 6 Dec 2021, Ning Li wrote:
> > Thanks for your reply.
> > After I added '--with-shared-libraries=0', the configuration stage
> > passed and now it is executing the 'make' command!
> > Thanks very much
> > On Mon, Dec 6, 2021 at 5:21 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > Executing: /home/LiNin/petsc-3.16.1/lib/petsc/bin/win32fe/win32fe
> > > ifort -o
> /cygdrive/c/Users/LiNin/AppData/Local/Temp/petsc-5ly209eh/config.libraries/c
> onftest.exe
> > >   -MD -O3 -fpp
> > > raries/conftest.o /cygdrive/c/Program\ Files\ \(x86\)/Microsoft\
> > > SDKs/MPI/Lib/x64/msmpi.lib /cygdrive/c/Program\ Files\
> > > \(x86\)/Microsoft\ SDKs/MPI/Lib/x64/msmpifec.lib Ws2_32.lib
> > > stdout: LINK : warning LNK4098: defaultlib 'LIBCMT' conflicts with
> > > use of other libs; use /NODEFAULTLIB:library <<<
> > > I'm not sure why this link command is giving this error. Can you
> > > retry with '--with-shared-libraries=0'?
> > > Satish
> > > > Howdy,
> > > > I am trying to install PETSc on windows with cygwin but got an mpi
> error.
> > > > Could you have a look at my issue and give me some instructions?
> > > > Here is the information about my environment:
> > > > 1. operation system: windows 11
> > > > 2. visual studio version: 2019
> > > > 3. intel one API toolkit is installed 4. Microsoft MS MPI is
> > > > installed.
> > > > 5. Intel MPI is uninstalled.
> > > > 6. PETSc version: 3.16.1
> > > > this is my configuration:
> > > > ./configure --with-cc='win32fe cl' --with-fc='win32fe ifort'
> > > > --prefix=~/petsc-opt/ --PETSC_ARCH=windows-intel-opt
> > > > --with-mpi-include=['/cygdrive/c/Program Files (x86)/Microsoft
> > > > SDKs/MPI/Include','/cygdrive/c/Program Files (x86)/Microsoft
> > > > SDKs/MPI/Include/x64'] --with-mpi-lib=['/cygdrive/c/Program Files
> > > > (x86)/Microsoft SDKs/MPI/Lib/x64/msmpi.lib','/cygdrive/c/Program
> > > > Files (x86)/Microsoft SDKs/MPI/Lib/x64/msmpifec.lib']
> > > > --with-blas-lapack-lib=['/cygdrive/c/Program Files
> > > (x86)/Intel/oneAPI/mkl/2021.3.0/lib/intel64/mkl_intel_lp64.lib','/cy
> > > gdrive/c/Program
> > > > Files
> > > (x86)/Intel/oneAPI/mkl/2021.3.0/lib/intel64/mkl_core.lib','/cygdrive
> > > /c/Program
> > > > Files
> > > > (x86)/Intel/oneAPI/mkl/2021.3.0/lib/intel64/mkl_sequential.lib']
> > > > --with-scalapack-include='/cygdrive/c/Program Files
> > > > (x86)/Intel/oneAPI/mkl/2021.3.0/include'
> > > > --with-scalapack-lib=['/cygdrive/c/Program Files
> > > (x86)/Intel/oneAPI/mkl/2021.3.0/lib/intel64/mkl_scalapack_lp64.lib',
> > > > Files
> > > > (x86)/Intel/oneAPI/mkl/2021.3.0/lib/intel64/mkl_blacs_msmpi_lp64.l
> > > > ib']
> > > > --with-fortran-interfaces=1 --with-debugging=0
> > > > attached is the configure.log file.
> > > > Thanks
> > > > Ning Li
