[petsc-users] DM/DMPlex Issue from DM vector access
Ferrand, Jesus A.
FERRANJ2 at my.erau.edu
Mon Dec 6 13:02:30 CST 2021
Dear PETSc Team:
I am a new PETSc user who is working on an FEA code and ran into an issue pertaining to DMPlex.
I have a gmsh mesh file that I import using "DMPlexCreateGmshFromFile()." I then fetch the XYZ coordinates of the nodes from this mesh using "DMGetCoordinatesLocal()." Deeper into the code, I have a call to "DMPlexGetTransitiveClosure()" inside a loop that scans the cells (I think you guys refer to it as "depth-3") to reference nodes. Here's the catch: If I attempt to reference the array from the vector (Vec) in the call to "DMGetCoordinatesLocal()" by using something like "VecGetArray()," or "VecGetArrayRead()," the call to "DMPlexGetTransitiveClosure()" errors-out with a segmentation fault. I need access to that vector's stored XYZ-data because I'm using my own finite element scripts. I have no clue as to why this is happening. Maybe it is a newbie mistake and I am forgetting to restore some memory?
Code, error message, and gmsh files are attached.
Your help is much appreciated.
Machine Type: HP Laptop
C-compiler: Gnu C
OS: Ubuntu 20.04
PETSc version: 3.16.0
MPI Implementation: MPICH
Sincerely:
J.A. Ferrand
Embry-Riddle Aeronautical University - Daytona Beach FL
M.Sc. Aerospace Engineering | May 2022
B.Sc. Aerospace Engineering
B.Sc. Computational Mathematics
Sigma Gamma Tau
Tau Beta Pi
Honors Program
Phone: (386)-843-1829
Email(s): ferranj2 at my.erau.edu
jesus.ferrand at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211206/bf811873/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211206/bf811873/attachment-0001.c>
Desc: TopOptmesh2.msh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211206/bf811873/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211206/bf811873/attachment-0001.txt>
