[petsc-users] How to read/write a HDF5 file using petsc4py ?
Matthew Knepley
knepley at gmail.com
Mon Dec 6 12:24:39 CST 2021
On Mon, Dec 6, 2021 at 1:22 PM Quentin Chevalier <
quentin.chevalier at polytechnique.edu> wrote:
> It failed all of the tests included in `make
> PETSC_DIR=/usr/local/petsc PETSC-ARCH=linux-gnu-real-32 check`, with
> the error `/usr/bin/bash: line 1: cd: src/snes/tutorials: No such file
> or directory`
> I am therefore fairly confident this a "file absence" problem, and not
> a compilation problem.
> I repeat that there was no error at compilation stage. The final stage
> did present `gmake[3]: Nothing to be done for 'libs'.` but that's all.
> Again, running `./configure --with-hdf5` followed by a `make
> PETSC_DIR=/usr/local/petsc PETSC-ARCH=linux-gnu-real-32 all` does not
> change the problem. I get the same error at the same position as
> before.
If you reconfigured and rebuilt, it is impossible to get the same error, so
a) You did not reconfigure
b) Your new build is somewhere else on the machine
Matt
> I will comment I am running on OpenSUSE.
> Quentin
> On Mon, 6 Dec 2021 at 19:09, Matthew Knepley <knepley at gmail.com> wrote:
> > On Mon, Dec 6, 2021 at 1:08 PM Quentin Chevalier <
> >> Hello Matthew and thanks for your quick response.
> >> I'm afraid I did try to snoop around the container and rerun PETSc's
> >> configure with the --with-hdf5 option, to absolutely no avail.
> >> I didn't see any errors during config or make, but it failed the tests
> >> (which aren't included in the minimal container I suppose)
> > Failed which tests? What was the error?
> > Thanks,
> > Matt
> >> Quentin
> >> Quentin CHEVALIER – IA parcours recherche
> >> LadHyX - Ecole polytechnique
> >> __________
> >> On Mon, 6 Dec 2021 at 19:02, Matthew Knepley <knepley at gmail.com> wrote:
> >> > On Mon, Dec 6, 2021 at 11:28 AM Quentin Chevalier <
> >> >> Hello PETSc users,
> >> >> This email is a duplicata of this gitlab issue, sorry for any
> inconvenience caused.
> >> >> I want to compute a PETSc vector in real mode, than perform
> calculations with it in complex mode. I want as much of this process to be
> parallel as possible. Right now, I compile PETSc in real mode, compute my
> vector and save it to a file, then switch to complex mode, read it, and
> move on.
> >> >> This creates unexpected behaviour using MPIIO, so on Lisandro
> Dalcinl's advice I'm moving to HDF5 format. My code is as follows (taking
> inspiration from petsc4py doc, a bitbucket example and another one, all top
> Google results for 'petsc hdf5') :
> >> >>> viewer = PETSc.Viewer().createHDF5(file_name, 'r', COMM_WORLD)
> >> >>> q.load(viewer)
> >> >>> q.ghostUpdate(addv=PETSc.InsertMode.INSERT,
> mode=PETSc.ScatterMode.FORWARD)
> >> >> This crashes my code. I obtain traceback :
> >> >>> File "/home/shared/code.py", line 121, in Load
> >> >>> File "PETSc/Viewer.pyx", line 182, in
> petsc4py.PETSc.Viewer.createHDF5
> >> >>> petsc4py.PETSc.Error: error code 86
> >> >>> [0] PetscViewerSetType() at
> /usr/local/petsc/src/sys/classes/viewer/interface/viewreg.c:442
> >> >>> [0] Unknown type. Check for miss-spelling or missing package:
> https://petsc.org/release/install/install/#external-packages
> >> >>> [0] Unknown PetscViewer type given: hdf5
> >> > This means that PETSc has not been configured with HDF5 (--with-hdf5
> or --download-hdf5), so the container should be updated.
> >> > THanks,
> >> > Matt
> >> >> I have petsc4py 3.16 from this docker container (list of
> dependencies include PETSc and petsc4py).
> >> >> I'm pretty sure this is not intended behaviour. Any insight as to
> how to fix this issue (I tried running ./configure --with-hdf5 to no avail)
> or more generally to perform this jiggling between real and complex would
> be much appreciated,
> >> >> Kind regards.
> >> >> Quentin
> >> > What most experimenters take for granted before they begin their
> experiments lead.
> >> > -- Norbert Wiener
> >> > https://www.cse.buffalo.edu/~knepley/
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211206/5a1e8b02/attachment.html>
