[petsc-users] CV_CONV_FAILURE with TSSUNDIALS in PETSc
Sanjoy Kumar Mazumder mazumder at purdue.edu
Mon Dec 6 11:16:52 CST 2021
Hi all,
I am trying to solve a set of coupled stiff ODEs in parallel using TSSUNDIALS with SUNDIALS_BDF as 'TSSundialsSetType' in PETSc. I am using a sparse Jacobian matrix of type MATMPIAIJ with no preconditioner. It runs for some time with a very small initial timestep (~10^-18) and then terminates abruptly with the following error:
[CVODE ERROR]  CVode
  At t = 1.83912e-06 and h = 3.74248e-13, the corrector convergence test failed repeatedly or with |h| = hmin.
Is there anything I am missing out or not doing properly? Given below is the complete error that is showing up after the termination.
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[5]PETSC ERROR:
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[7]PETSC ERROR:
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[16]PETSC ERROR:
[CVODE ERROR]  CVode
[CVODE ERROR]  CVode
[19]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[19]PETSC ERROR: Error in external library
[19]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[19]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[19]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[19]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[19]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[19]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[19]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[19]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[19]PETSC ERROR: #4 User provided function() line 0 in User file
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Error in external library
[0]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[0]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[0]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[0]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[0]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[0]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[0]PETSC ERROR: #4 User provided function() line 0 in User file
[1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[1]PETSC ERROR: Error in external library
[1]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[1]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[1]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[2]PETSC ERROR: Error in external library
[2]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[2]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[2]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[2]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[2]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[2]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[2]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[2]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[2]PETSC ERROR: #4 User provided function() line 0 in User file
[3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[3]PETSC ERROR: Error in external library
[3]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[3]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[3]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[3]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[3]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[3]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[3]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[3]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[3]PETSC ERROR: #4 User provided function() line 0 in User file
[4]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[4]PETSC ERROR: Error in external library
[4]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[4]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[4]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[4]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[4]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[4]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[5]PETSC ERROR: Error in external library
[5]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[5]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[5]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[5]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[5]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[5]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[5]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[5]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[5]PETSC ERROR: #4 User provided function() line 0 in User file
[7]PETSC ERROR: Error in external library
[7]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[7]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[7]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[7]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[7]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[7]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[7]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[7]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[7]PETSC ERROR: #4 User provided function() line 0 in User file
[8]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[8]PETSC ERROR: Error in external library
[8]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[8]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[8]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[8]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[9]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[9]PETSC ERROR: Error in external library
[9]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[9]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[9]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[9]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[9]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[9]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[9]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[9]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[10]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[10]PETSC ERROR: Error in external library
[10]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[10]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[10]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[10]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[10]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[10]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[10]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[10]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[10]PETSC ERROR: #4 User provided function() line 0 in User file
[11]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[11]PETSC ERROR: Error in external library
[11]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[11]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[11]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[11]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[11]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[11]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[11]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[11]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[11]PETSC ERROR: #4 User provided function() line 0 in User file
[12]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[12]PETSC ERROR: Error in external library
[12]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[12]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[12]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[12]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[12]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[12]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[12]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[12]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[12]PETSC ERROR: #4 User provided function() line 0 in User file
[14]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[14]PETSC ERROR: Error in external library
[14]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[14]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[14]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[14]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[14]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[14]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[15]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[15]PETSC ERROR: Error in external library
[15]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[15]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[15]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[16]PETSC ERROR: Error in external library
[16]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[16]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[16]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[16]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[16]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[16]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[16]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[16]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[16]PETSC ERROR: #4 User provided function() line 0 in User file
[17]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[17]PETSC ERROR: Error in external library
[17]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[17]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[17]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[17]PETSC ERROR: [18]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[18]PETSC ERROR: Error in external library
[18]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[18]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[18]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[18]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[17]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[17]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[17]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[17]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[17]PETSC ERROR: #4 User provided function() line 0 in User file
[1]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[1]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[1]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[1]PETSC ERROR: #4 User provided function() line 0 in User file
[4]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[4]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[4]PETSC ERROR: #4 User provided function() line 0 in User file
[8]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[8]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[8]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[8]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[8]PETSC ERROR: #4 User provided function() line 0 in User file
[9]PETSC ERROR: #4 User provided function() line 0 in User file
[13]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[13]PETSC ERROR: Error in external library
[13]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[13]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[13]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[13]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[13]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[13]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[13]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[13]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[13]PETSC ERROR: #4 User provided function() line 0 in User file
[14]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[14]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[14]PETSC ERROR: #4 User provided function() line 0 in User file
[15]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[15]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[15]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[15]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[15]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[15]PETSC ERROR: #4 User provided function() line 0 in User file
[18]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[18]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[18]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[18]PETSC ERROR: #4 User provided function() line 0 in User file
[6]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[6]PETSC ERROR: Error in external library
[6]PETSC ERROR: CVode() fails, CV_CONV_FAILURE
[6]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[6]PETSC ERROR: Petsc Release Version 3.14.5, Mar 03, 2021
[6]PETSC ERROR: ./ThO2_CD2_P on a arch-linux-c-debug named bell-a027.rcac.purdue.edu by mazumder Mon Dec  6 11:45:05 2021
[6]PETSC ERROR: Configure options --with-cc-mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-fblaslapack --download-sundials=yes --with-debugging
[6]PETSC ERROR: #1 TSStep_Sundials() line 156 in /home/mazumder/petsc-3.14.5/src/ts/impls/implicit/sundials/sundials.c
[6]PETSC ERROR: #2 TSStep() line 3759 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[6]PETSC ERROR: #3 TSSolve() line 4156 in /home/mazumder/petsc-3.14.5/src/ts/interface/ts.c
[6]PETSC ERROR: #4 User provided function() line 0 in User file
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
with errorcode 76.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[bell-a027.rcac.purdue.edu:29752] 15 more processes have sent help message help-mpi-api.txt / mpi-abort
[bell-a027.rcac.purdue.edu:29752] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
Thanks
With regards,
Sanjoy
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211206/69608a51/attachment-0001.html>
