[petsc-users] KSPBuildResidual and KSPType compatibility
Barry Smith bsmith at petsc.dev
Mon Dec 6 10:58:22 CST 2021
  This algorithm computes the residual norms indirectly (this is part of the "trick" of the algorithm to reduce the number of global reductions needed), thus they may not match the actual residual norm computed by || b - A x ||. How different are your values?
  Barry
> On Dec 6, 2021, at 11:19 AM, Fischer, Greg A. via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello petsc-users,
> I would like to check convergence against the infinity norm, so I defined my own convergence test routine with KSPSetConvergenceTest. (I understand that it may be computationally expensive.)
> I would like to do this with the “ibcgs” method. When I use KSPBuildResidual and calculate the NORM_2 against the output vector, I get a value that differs from the 2-norm that gets passed into the convergence test function. However, when I switch to the “gcr” method, the value I calculate matches the function input value.
> Is the KSPBuildResidual function only compatible with a subset of the KSPType methods? If I want to evaluate convergence against the infinity norm, do I need to set KSPSetInitialGuessNonzero and continually re-start the solver with a lower tolerance values until I get a satisfactory value of the infinity norm?
> Thanks,
> Greg
> This e-mail may contain proprietary information of the sending organization. Any unauthorized or improper disclosure, copying, distribution, or use of the contents of this e-mail and attached document(s) is prohibited. The information contained in this e-mail and attached document(s) is intended only for the personal and private use of the recipient(s) named above. If you have received this communication in error, please notify the sender immediately by email and delete the original e-mail and attached document(s).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211206/bf9c0369/attachment.html>
