[petsc-users] Communication in parallel MatMatMult
Barry Smith bsmith at petsc.dev
Wed Dec 1 08:32:13 CST 2021
  PETSc uses Elemental to perform such operations.
PetscErrorCode MatMatMultNumeric_Elemental(Mat A,Mat B,Mat C)
  Mat_Elemental    *a = (Mat_Elemental*)A->data;
  Mat_Elemental    *b = (Mat_Elemental*)B->data;
  Mat_Elemental    *c = (Mat_Elemental*)C->data;
  PetscElemScalar  one = 1,zero = 0;
  PetscFunctionBegin;
  { /* Scoping so that constructor is called before pointer is returned */
    El::Gemm(El::NORMAL,El::NORMAL,one,*a->emat,*b->emat,zero,*c->emat);
  C->assembled = PETSC_TRUE;
  PetscFunctionReturn(0);
You can consult Elemental's documentation and papers for how it manages the communication.
 Barry
> On Dec 1, 2021, at 8:33 AM, Hannes Brandt <Hannes_Brandt at gmx.de> wrote:
> Hello,
> I am interested in the communication scheme Petsc uses for the multiplication of dense, parallel distributed matrices in MatMatMult. Is it based on collective communication or on single calls to MPI_Send/Recv, and is it done in a blocking or a non-blocking way? How do you make sure that the processes do not receive/buffer too much data at the same time?
> Best Regards,
> Hannes Brandt
