[petsc-users] Mat preallocation in case of variable stencils
Matteo Semplice
matteo.semplice at uninsubria.it
Tue Aug 31 09:50:11 CDT 2021
Hi.
We are writing a code for a FD scheme on an irregular domain and thus
the local stencil is quite variable: we have inner nodes, boundary nodes
and inactive nodes, each with their own stencil type and offset with
respect to the grid node. We currently create a matrix with
DMCreateMatrix on a DMDA and for now have set the option
MAT_NEW_NONZERO_LOCATIONS to PETSC_TRUE, but its time to render the code
memory-efficient. The layout created automatically is correct for inner
nodes, wrong for boundary ones (off-centered stencils) and redundant for
outer nodes.
After the preprocessing stage (including stencil creation) we'd be in
position to set the nonzero pattern properly.
Do we need to start from a Mat created by CreateMatrix? Or is it ok to
call DMCreateMatrix (so that the splitting among CPUs and the block size
are set by PETSc) and then call a MatSetPreallocation routine?
Also, I've seen in some examples that you call the Seq and the MPI
preallocation routines in a row. Does this work because
MatMPIAIJSetPreallocation silently does nothing on a Seq matrix and
viceversa?
Thanks
Matteo
