[petsc-users] PETSc 3.15.3 compiling error
Satish Balay
balay at mcs.anl.gov
Mon Aug 30 23:47:47 CDT 2021
Also - what do you have for:
grep MUMPS_VERSION /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/*.h
Satish
On Mon, 30 Aug 2021, Satish Balay via petsc-users wrote:
> please resend the logs
> Satish
> On Mon, 30 Aug 2021, Sam Guo wrote:
> > Same compiling error with --with-mumps-serial=1.
> > On Mon, Aug 30, 2021 at 8:22 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > Use the additional option: -with-mumps-serial
> > > Satish
> > > > Attached please find the configure.log. I use my own CMake. I have
> > > > defined -DPETSC_HAVE_MUMPS. Thanks.
> > > > On Mon, Aug 30, 2021 at 4:56 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
> > > > > I use pre-installed
> > > > > On Mon, Aug 30, 2021 at 4:53 PM Satish Balay <balay at mcs.anl.gov>
> > > wrote:
> > > > >> Are you using --download-mumps or pre-installed mumps? If using
> > > > >> pre-installed - try --download-mumps.
> > > > >> If you still have issues - send us configure.log and make.log from the
> > > > >> failed build.
> > > > >> Satish
> > > > >> > Dear PETSc dev team,
> > > > >> > I am compiling petsc 3.15.3 and got following compiling error
> > > > >> > petsc/src/mat/impls/aij/mpi/mumps/mumps.c:52:31: error: missing
> > > binary
> > > > >> > operator before token "("
> > > > >> > 52 | #if PETSC_PKG_MUMPS_VERSION_GE(5,3,0)
> > > > >> > Any idea what I did wrong?
> > > > >> > Thanks,
> > > > >> > Sam
