[petsc-users] issues with mpi uni
Janne Ruuskanen (TAU)
janne.ruuskanen at tuni.fi
Tue Aug 24 04:47:23 CDT 2021
PETSc was built without mpi with the command:
./configure --with-openmp --with-mpi=0 --with-shared-libraries=1 --with-mumps-serial=1 --download-mumps --download-openblas --download-metis --download-slepc --with-debugging=0 --with-scalar-type=real --with-x=0 COPTFLAGS='-O3' CXXOPTFLAGS='-O3' FOPTFLAGS='-O3';
so the MPI_UNI mpi wrapper of petsc collides in names with the actual MPI used to compile sparselizard.
-Janne
-----Original Message-----
Sent: Monday, August 23, 2021 4:45 PM
To: Janne Ruuskanen (TAU) <janne.ruuskanen at tuni.fi>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] issues with mpi uni
Did you build PETSc with the same openmpi [as what sparselizard is built with]?
Satish
On Mon, 23 Aug 2021, Janne Ruuskanen (TAU) wrote:
> Hi,
> Assumingly, I have an issue using petsc and openmpi together in my c++ code.
> See the code there:
> https://github.com/halbux/sparselizard/blob/master/src/slmpi.cpp
> So when I run:
> slmpi::initialize();
> slmpi::count();
> slmpi::finalize();
> I get the following error:
> *** The MPI_Comm_size() function was called before MPI_INIT was invoked.
> *** This is disallowed by the MPI standard.
> *** Your MPI job will now abort.
> Have you experienced anything similar with people trying to link openmpi and petsc into the same executable?
> Best regards,
> Janne Ruuskanen
