[petsc-users] Reaching limit number of communicator with Spectrum MPI
    Feimi Yu
    yuf2 at rpi.edu
    Fri Aug 20 13:54:22 CDT 2021
Hi Barry and Junchao,
Actually I did a simple MPI "dup and free" test before with Spectrum
MPI, but that one did not have any problem. I'm not a PETSc programmer
as I mainly use deal.ii's PETSc wrappers, but I managed to write a
minimal program based on petsc/src/mat/tests/ex98.c to reproduce my
problem. This piece of code creates and destroys 10,000 instances of
Hypre Parasail preconditioners (for my own code, it uses Euclid, but I
don't think it matters). It runs fine with OpenMPI but reports the out
of communicator error with Sepctrum MPI. The code is attached in the
email. In case the attachment is not available, I also uploaded a copy
on my google drive:
https://drive.google.com/drive/folders/1DCf7lNlks8GjazvoP7c211ojNHLwFKL6?usp=sharing
Thanks!
Feimi
On 8/20/21 9:58 AM, Junchao Zhang wrote:
> Feimi, if it is easy to reproduce, could you give instructions on how
> to reproduce that?
> PS: Spectrum MPI is based on OpenMPI.  I don't understand why it has
> the problem but OpenMPI does not.  It could be a bug in petsc or
> user's code.  For reference counting on MPI_Comm, we already have
> petsc inner comm. I think we can reuse that.
> --Junchao Zhang
> On Fri, Aug 20, 2021 at 12:33 AM Barry Smith <bsmith at petsc.dev
> <mailto:bsmith at petsc.dev>> wrote:
>       It sounds like maybe the Spectrum MPI_Comm_free() is not
>     returning the comm to the "pool" as available for future use; a
>     very buggy MPI implementation. This can easily be checked in a
>     tiny standalone MPI program that simply comm dups and frees
>     thousands of times in a loop. Could even be a configure test (that
>     requires running an MPI program). I do not remember if we ever
>     tested this possibility; maybe and I forgot.
>       If this is the problem we can provide a "work around" that
>     attributes the new comm (to be passed to hypre) to the old comm
>     with a reference count value also in the attribute. When the hypre
>     matrix is created that count is (with the new comm) is set to 1,
>     when the hypre matrix is freed that count is set to zero (but the
>     comm is not freed), in the next call to create the hypre matrix
>     when the attribute is found, the count is zero so PETSc knows it
>     can pass the same comm again to the new hypre matrix.
>     This will only allow one simultaneous hypre matrix to be created
>     from the original comm. To allow multiply simultaneous hypre
>     matrix one could have multiple comms and counts in the attribute
>     and just check them until one finds an available one to reuse (or
>     creates yet another one if all the current ones are busy with
>     hypre matrices). So it is the same model as DMGetXXVector() where
>     vectors are checked out and then checked in to be available later.
>     This would solve the currently reported problem (if it is a buggy
>     MPI that does not properly free comms), but not solve the MOOSE
>     problem where 10,000 comms are needed at the same time.
>       Barry
>>     On Aug 19, 2021, at 3:29 PM, Junchao Zhang
>>     <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>>     On Thu, Aug 19, 2021 at 2:08 PM Feimi Yu <yuf2 at rpi.edu
>>     <mailto:yuf2 at rpi.edu>> wrote:
>>         Hi Jed,
>>         In my case, I only have 2 hypre preconditioners at the same
>>         time, and
>>         they do not solve simultaneously, so it might not be case 1.
>>         I checked the stack for all the calls of
>>         MPI_Comm_dup/MPI_Comm_free on
>>         my own machine (with OpenMPI), all the communicators are
>>         freed from my
>>         observation. I could not test it with Spectrum MPI on the
>>         clusters
>>         immediately because all the dependencies were built in
>>         release mode.
>>         However, as I mentioned, I haven't had this problem with
>>         OpenMPI before,
>>         so I'm not sure if this is really an MPI implementation
>>         problem, or just
>>         because Spectrum MPI has less limit for the number of
>>         communicators,
>>         and/or this also depends on how many MPI ranks are used, as
>>         only 2 out
>>         of 40 ranks reported the error.
>>     You can add printf around MPI_Comm_dup/MPI_Comm_free sites on the
>>     two ranks, e.g., if (myrank == 38) printf(...), to see if the
>>     dup/free are paired.
>>      As a workaround, I replaced the MPI_Comm_dup() at
>>         petsc/src/mat/impls/hypre/mhypre.c:2120 with a copy
>>         assignment, and also
>>         removed the MPI_Comm_free() in the hypre destroyer. My code
>>         runs fine
>>         with Spectrum MPI now, but I don't think this is a long-term
>>         solution.
>>         Thanks!
>>         Feimi
>>         On 8/19/21 9:01 AM, Jed Brown wrote:
>>         > Junchao Zhang <junchao.zhang at gmail.com
>>         <mailto:junchao.zhang at gmail.com>> writes:
>>         >> Hi, Feimi,
>>         >>    I need to consult Jed (cc'ed).
>>         >>    Jed, is this an example of
>>         https://lists.mcs.anl.gov/mailman/htdig/petsc-dev/2018-April/thread.html#22663
>>         <https://lists.mcs.anl.gov/mailman/htdig/petsc-dev/2018-April/thread.html#22663>?
>>         >> If Feimi really can not free matrices, then we just need
>>         to attach a
>>         >> hypre-comm to a petsc inner comm, and pass that to hypre.
>>         > Are there a bunch of solves as in that case?
>>         > My understanding is that one should be able to
>>         MPI_Comm_dup/MPI_Comm_free as many times as you like, but the
>>         implementation has limits on how many communicators can
>>         co-exist at any one time. The many-at-once is what we
>>         encountered in that 2018 thread.
>>         > One way to check would be to use a debugger or tracer to
>>         examine the stack every time (P)MPI_Comm_dup and
>>         (P)MPI_Comm_free are called.
>>         > case 1: we'll find lots of dups without frees (until the
>>         end) because the user really wants lots of these existing at
>>         the same time.
>>         > case 2: dups are unfreed because of reference counting
>>         issue/inessential references
>>         > In case 1, I think the solution is as outlined in the
>>         thread, PETSc can create an inner-comm for Hypre. I think I'd
>>         prefer to attach it to the outer comm instead of the PETSc
>>         inner comm, but perhaps a case could be made either way.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210820/aa5ddfc6/attachment-0001.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210820/aa5ddfc6/attachment-0001.bin>
