[petsc-users] Parallelize in the y direction
Fri Aug 20 09:14:51 CDT 2021
On Fri, Aug 20, 2021 at 7:53 AM Joauma Marichal <
joauma.marichal at uclouvain.be> wrote:
>  Dear Sir or Madam,
> I am looking for advice regarding some of PETSc functionnalities. I am
> currently using PETSc to solve the Navier-Stokes equations on a 3D mesh
> decomposed over several processors.  However, until now, the processors are
> distributed along the x and z directions but not along the y one. Indeed,
> at some point in the algorithm, I must solve a tridiagonal system that
> depends only on y. Until now, I have therefore performed something like
> this:
> for(int k = cornp->zs, k<cornp->zs+cornp->zm; ++k){
>      for(int i = cornp->xs, i<cornp->xs+cornp->xm; ++i){
>            Create and solve a tridiagonal system for all the y coordinates
> (which are on the same process)
> However, I would like to decompose my mesh in the y direction (as this
> should improve the code efficiency).
> I managed to do so by creating a system based on the 3D DM of all my case
> (so 1 system of size x*y*z). Unfortunately, this does not seem to be very
> efficient.
> Do you have some advice on how to cut in the y direction while still being
> able to solve x*z systems of size y? Should I create 1D DMs?
1) Are you using a 3D DMDA?
2) Is the coupling much different in the x and z than in the y direction?
     Matt
> Thanks a lot for your help.
> Best regards,
> Joauma Marichal
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210820/b3a0572c/attachment.html>
