[petsc-users] malloc error
Jed Brown
jed at jedbrown.org
Mon Aug 16 23:40:20 CDT 2021
"Jorti, Zakariae via petsc-users" <petsc-users at mcs.anl.gov> writes:
> Hello,
> I am using TSSolve to solve a linear problem.
> In the FormIJacobian function that I provide to TSSetIJacobian, I first set the coefficients of both J and Jpre matrices the same way (J and Jpre matrices are equal in the first step). Then I call MatAXPY to prepare Jpre (Jpre := Jpre - another_matrix. So, Jpre and J are not equal anymore).
How do you call MatAXPY? What MatStructure arg are you passing? What is the sparsity pattern of another_matrix relative to Jpre?
> But I get the error once FormIJacobian is called the second time inside TSSolve:
> "[0]PETSC ERROR: New nonzero at (5,1) caused a malloc
> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off this check".
> It looks like MatAXPY changes the allocation of Jpre, which the second FormIJacobian does not like unless Jpre is destroyed first.
> Do you have any suggestions to fix this malloc issue?
> Thanks.
> Best regards,
> Zakariae
