[petsc-users] Sparse Matrix Matrix Multiply
Alfredo J Duarte Gomez aduarteg at utexas.edu
Thu Aug 12 09:43:59 CDT 2021
Good morning,
I am currently having some trouble in the creation of some matrices.
I am using structured dmda objects to create matrices using the DMCreate()
function.
One of these matrices will be the result of a matrix-matrix product of two
of these dm matrices.
I know that the matrix product will have more nonzero entries or at least a
bigger stencil than the original dm matrices, however I accounted for that
when I set the DMDA stencil width in the initial creation.
The problem is that even with that, the resulting matrix-matrix product has
a bigger stencil as evidenced by failure in subsequent matrix copy/addition
operations using SAME_NONZERO_PATTERN.
Judging by the difference of the nonzero entries I believe that initial
zero entries (the ones I initialized to eventually hold this
expaned stencil) on the original dm matrices are being combined to further
expand the stencil of the product matrix.
Is there any way of getting a matrix-matrix product that will keep the same
nonzero pattern as the dm matrices?
I have tried both MatMatMult() and the MatProductCreate() sequence so far,
but both produce nonzero patterns that do not match the dm nonzero pattern.
Thank you,
-Alfredo
Alfredo Duarte
Graduate Research Assistant
The University of Texas at Austin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210812/d301a57b/attachment.html>
