[petsc-users] PCFIELDSPLIT and Block Matrices
Barry Smith
bsmith at petsc.dev
Fri Aug 6 21:11:45 CDT 2021
> On Aug 6, 2021, at 5:26 PM, Alfredo J Duarte Gomez <aduarteg at utexas.edu> wrote:
> Good morning,
> I am currently working on a PETSC application that will require a preconditioner that uses several block matrices.
> For now, I have a simple problem that I am solving with a dmda structured grid with two fields. For presentation purposes (I know petsc does not use this ordering), lets assume a vector ordering [u1,u2,...,uN,v1,v2,...vN] where u and v are my two fields with N number of grid points. The coupling between these two fields is weak enough that an efficient preconditioner can be formed as the matrix P = [A1, 0;0,A2] where A1 (dependent on u only) and A2 (dependent on v only) are block matrices of size NxN. Therefore, I only require two linear solves of the reduced systems.
> I am passing the preconditioner matrix P in the Jacobian function, and I hope this strategy is what I am telling PETSC to do with the following block of code:
> ierr = KSPGetPC(snes,&pc);CHKERRQ(ierr);CHKERRQ(ierr);
> ierr = PCSetType(pc,PCFIELDSPLIT);CHKERRQ(ierr);
> ierr = DMCreateFieldDecomposition(dau,NULL,NULL,&fields,NULL);CHKERRQ(ierr);
> ierr = PCFieldSplitSetIS(pc,NULL,fields[0]);CHKERRQ(ierr);
> ierr = PCFieldSplitSetIS(pc,NULL,fields[1]);CHKERRQ(ierr);
> Is this what is actually happening, or is the split also including some of the zero blocks on P?
You should also use PCFieldSplitSetType(pc,PC_COMPOSITE_ADDITIVE) then the preconditioned problem will look like
[ KSPSolve(A1) ; 0 ] [ A1 A12 ]
[ 0 ; KSPSolve(A2) ] [ A21 A22 ]
in other words the preconditioner is
[A1 0 ]
approximate inverse ( )
[ 0 A2 ]
the computation is done efficiently and never uses the zero blocks.
The default PCFieldSplitType is PC_COMPOSITE_MULTIPLICATIVE where the preconditioner system looks like
[A1 0 ]
[ A12 A2 ]
The preconditioner is applied efficiently by first (approximately) solving with A1, then applying A12 to that (approximate) solution, removing it from the right hand side of the second block and then (approximately) solving with A2.
Note that if you are using DMDA you don't need to write the above code you can use -pc_type fieldsplit -pc_fieldsplit_type additive and it will use the fields as you would like.
> Second, for a future application, I will need a slightly more complicated strategy. It will require solving a similar matrix to P as specified above with more fields (Block diagonal for the fields), and then using the answer to those independent systems for a smaller local solves. In summary, if i have M fields and N grid points, I will solve M systems of size N then followed by using solution as the right hand side to solve N systems of size M.
It sounds like a block diagonal preconditioner (with one block per field) in one ordering then changing the ordering and doing another block diagonal preconditioner with one block for each grid point. PCFIELDSPLIT cannot do this since it basically works with a single ordering.
You might be able to combine multiple preconditioners using PCCOMPOSITE that does a PCFIELDSPLIT then a PCPBJACOBI. Again you have a choice of additive or multiplicative formulation. You should not need to use PCSHELL. In fact you should not have to write any code, you should be able to control it completely from the options database with, maybe, -pc_type composite -pc_composite_pcs fieldsplit,pbjacobi -pc_composite_type additive
You can also control the solvers used on the inner solves from the options database. If you run with -ksp_view it will show the options prefix for each inner solve and you can use them to control the fields solvers, for example, using gamg for one of the fields in the PCFIELDSPLIT.
> Is this something that the PCFIELDSPLIT can accomodate? Or will I have to implement my own PCSHELL?
> Thank you,
> -Alfredo
> Alfredo Duarte
> Graduate Research Assistant
> The University of Texas at Austin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210806/c19778aa/attachment.html>
