[petsc-users] Detecting steady-state with TS
Mark Adams
mfadams at lbl.gov
Fri Apr 30 17:55:40 CDT 2021
You could add a
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSMonitorSet.html
method, compute the time derived and decide how to declare converged.
Then set converged (
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSSetConvergedReason.html)
with TS_CONVERGED_USER
That should cause TS to wrap up the solve and exit cleanly.
On Thu, Apr 29, 2021 at 3:27 PM Salazar De Troya, Miguel via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> I am solving the signed distance equation
> \frac{\partial \phi}{\partial t} + sign (\phi_{0})(|\nabla \phi| - 1) = 0
> using a Local Discontinuous Galerkin (LDG) method as described in
> https://www.sciencedirect.com/science/article/pii/S0021999110005255
> I am interested in solving it close to steady state. I was hoping I could
> measure how close to steady state the solution is by using the
> TSSetEventHandler infrastructure, but the handler does not have information
> on the time derivative. I looked at TSPSEUDO, but it forces me to use an
> implicit method, which I cannot provide because how the LDG method works
> (it calculates the fluxes solving additional equations). This makes me
> wonder if the LDG method is the best choice, so I am open to suggestions.
> Given my current progress with the LDG approach, I am wondering if there
> is a way to solve to steady state using explicit algorithms such as
> Runge-Kutta.
> Thanks
> Miguel
> Miguel A. Salazar de Troya
> Postdoctoral Researcher, Lawrence Livermore National Laboratory
> B141
> Rm: 1085-5
> Ph: 1(925) 422-6411
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210430/81958b1f/attachment.html>
