[petsc-users] Parallel TS for ODE
Stefano Zampini
stefano.zampini at gmail.com
Thu Apr 29 03:52:07 CDT 2021
There are many examples that uses 1d DMDA in time dependent problems within
the source tree. You can take a look at them first.
Let us know if none of them do what you need.
[szampini at localhost petsc]$ git grep DMDACreate1 src/ts/
src/ts/tests/ex12.c: ierr =
DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,appctx.m,1,1,NULL,&appctx.da);CHKERRQ(ierr);
src/ts/tests/ex22.c: ierr =
DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,-n,1,1,0,&da);CHKERRQ(ierr);
src/ts/tests/ex25.c: ierr =
DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,11,2,2,NULL,&da);CHKERRQ(ierr);
src/ts/tutorials/advection-diffusion-reaction/ex3.c: ierr =
DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_PERIODIC, 60, 1,
1,NULL,&da);CHKERRQ(ierr);
src/ts/tutorials/advection-diffusion-reaction/ex4.c: ierr =
DM_BOUNDARY_NONE,8,2,1,NULL,&da);CHKERRQ(ierr);
src/ts/tutorials/advection-diffusion-reaction/ex6.c: ierr =
src/ts/tutorials/ex10.c: ierr =
DMDACreate1d(comm,DM_BOUNDARY_NONE,M,1,0,lx,&da);CHKERRQ(ierr);
DMDACreate1d(comm,DM_BOUNDARY_NONE,20,sizeof(RDNode)/sizeof(PetscScalar),1,NULL,&rd->da);CHKERRQ(ierr);
src/ts/tutorials/ex17.c: ierr =
DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,11,1,1,NULL,&da);CHKERRQ(ierr);
src/ts/tutorials/ex2.c: ierr =
src/ts/tutorials/ex21.c: ierr =
src/ts/tutorials/ex22.c: ierr =
src/ts/tutorials/ex22f.F: call
DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,im11,i2,i2, &
src/ts/tutorials/ex22f_mf.F90: call
DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,im11,i2,i2,PETSC_NULL_INTEGER,da,ierr);CHKERRA(ierr)
src/ts/tutorials/ex25.c: ierr =
src/ts/tutorials/ex34.c: ierr = DMDACreate1d(PETSC_COMM_WORLD,
DM_BOUNDARY_NONE, 11, 3, 1, NULL, &dm);CHKERRQ(ierr);
src/ts/tutorials/ex4.c: ierr =
DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,m,1,1,NULL,&appctx.da);CHKERRQ(ierr);
src/ts/tutorials/ex50.c: ierr =
DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_PERIODIC,lenglob,1,1,NULL,&appctx.da);CHKERRQ(ierr);
src/ts/tutorials/ex9.c: ierr =
DMDACreate1d(comm,DM_BOUNDARY_PERIODIC,50,ctx.physics.dof,2,NULL,&da);CHKERRQ(ierr);
src/ts/tutorials/extchemfield.c: ierr =
DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_PERIODIC,10,user.Nspec+1,1,NULL,&
user.dm);CHKERRQ(ierr);
src/ts/tutorials/multirate/ex5.c: ierr =
src/ts/tutorials/multirate/ex6.c: ierr =
DMDACreate1d(comm,DM_BOUNDARY_PERIODIC,50,ctx.physics2.dof,2,NULL,&da);CHKERRQ(ierr);
src/ts/tutorials/multirate/ex7.c: ierr =
src/ts/tutorials/multirate/ex8.c: ierr =
src/ts/tutorials/network/wash/pipeInterface.c: ierr =
DMDACreate1d(PETSC_COMM_SELF, DM_BOUNDARY_GHOSTED, pipe->nnodes, 2, 1,
NULL, &pipe->da);CHKERRQ(ierr);
src/ts/tutorials/phasefield/biharmonic.c: ierr =
DMDACreate1d(PETSC_COMM_WORLD, DM_BOUNDARY_PERIODIC,
10,1,2,NULL,&da);CHKERRQ(ierr);
src/ts/tutorials/phasefield/biharmonic2.c: ierr =
10,2,2,NULL,&da);CHKERRQ(ierr);
src/ts/tutorials/phasefield/biharmonic3.c: ierr =
src/ts/tutorials/phasefield/heat.c: ierr = DMDACreate1d(PETSC_COMM_WORLD,
DM_BOUNDARY_PERIODIC, 10,1,2,NULL,&da);CHKERRQ(ierr);
src/ts/tutorials/power_grid/stability_9bus/ex9bus.c: ierr =
DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,user.neqs_gen,1,1,NULL,&user.dmgen);CHKERRQ(ierr);
DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,user.neqs_net,1,1,NULL,&user.dmnet);CHKERRQ(ierr);
src/ts/tutorials/power_grid/stability_9bus/ex9busadj.c: ierr =
src/ts/tutorials/power_grid/stability_9bus/ex9busopt.c: ierr =
src/ts/tutorials/power_grid/stability_9bus/ex9busoptfd.c: ierr =
Il giorno gio 29 apr 2021 alle ore 10:57 Francesco Brarda <
brardafrancesco at gmail.com> ha scritto:
> Hi,
> The plan is actually to move to a SIR model also with the space.
> I understand that doing a SIR model in parallel will not bring any
> benefits, but I have been asked to do it as part of a project I am involved
> in.
> I defined the DM as follows
> ierr =
> DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE,3,3,3,NULL,&da);CHKERRQ(ierr);
> I am not sure whether I correctly understood this command properly. The
> vector should have 3 components (S, I, R) and 3 DOF as it is defined
> only when the three coordinates have been set.
> Then I create a global vector X. When I set the initial conditions
> as below
> static PetscErrorCode InitialConditions(TS ts,Vec X, void *ctx)
> PetscErrorCode ierr;
> AppCtx *appctx = (AppCtx*) ctx;
> PetscScalar *x;
> DM da;
> PetscFunctionBeginUser;
> ierr = TSGetDM(ts,&da);CHKERRQ(ierr);
> /* Get pointers to vector data */
> ierr = DMDAVecGetArray(da,X,(void*)&x);CHKERRQ(ierr);
> x[0] = appctx->N - appctx->p[2];
> x[1] = appctx->p[2];
> x[2] = 0.0;
> ierr = DMDAVecRestoreArray(da,X,(void*)&x);CHKERRQ(ierr);
> PetscFunctionReturn(0);
> I have the error:
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Wrong subtype object:Parameter # 1 must have
> implementation da it is shell
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.14.4, unknown
> [0]PETSC ERROR: ./par_sir_model on a arch-debug named srvulx13 by fbrarda
> Thu Apr 29 09:36:17 2021
> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --with-openblas-dir=/opt/packages/openblas/0.2.13-gcc
> --download-mpich PETSC_ARCH=arch-debug
> [0]PETSC ERROR: #1 DMDAVecGetArray() line 48 in
> /home/fbrarda/petsc/src/dm/impls/da/dagetarray.c
> [0]PETSC ERROR: #2 InitialConditions() line 175 in par_sir_model.c
> [0]PETSC ERROR: #3 main() line 295 in par_sir_model.c
> [0]PETSC ERROR: No PETSc Option Table entries
> I would be very happy to receive any advices to fix the code.
> Best,
> Francesco
> Il giorno 20 apr 2021, alle ore 21:35, Matthew Knepley <knepley at gmail.com>
> ha scritto:
> On Tue, Apr 20, 2021 at 1:17 PM Francesco Brarda <
> brardafrancesco at gmail.com> wrote:
> Thank you for the advices, I would just like to convert the code I already
> have to see what might happen once parallelized.
> Do you think it is better to put the 3 equations into a 1d Distributed
> Array with 3 dofs and run the job with multiple procs regardless of
> how many equations I have? Is it possible?
> If you plan in the end to use a structured grid, this is a great plan. If
> not, this is not a good plan.
> Thanks,
> Matt
> Thank you,
> Francesco
> Il giorno 20 apr 2021, alle ore 17:57, Stefano Zampini <
> stefano.zampini at gmail.com> ha scritto:
> It does not make sense to parallelize to 1 equation per process, unless
> that single equation per process is super super super costly.
> Is this work you are doing used to understand PETSc parallelization
> strategy? if so, there are multiple examples in the sourcetree that you can
> look at to populate matrices and vectors in parallel
> Il giorno mar 20 apr 2021 alle ore 17:52 Francesco Brarda <
> In principle the entire code was for 1 proc only. The functions were built
> with VecGetArray(). While adapting the code for multiple procs I thought
> using VecGetOwnershipRange was a possible way to allocate the equations in
> the vector using multiple procs. What do you think, please?
> Thank you,
> Francesco
> Il giorno 20 apr 2021, alle ore 16:43, Matthew Knepley <knepley at gmail.com>
> ha scritto:
> On Tue, Apr 20, 2021 at 10:41 AM Francesco Brarda <
> I was trying to follow Barry's advice some time ago, but I guess that's
> not the way he meant it. How should I refer to the values contained in x?
> With Distributed Arrays?
> That is how you get values from x. However, I cannot understand at all
> what you are doing with "mybase".
> Matt
> Thanks
> Francesco
> Even though it will not scale and will deliver slower performance it is
> completely possible for you to solve the 3 variable problem using 3 MPI
> ranks. Or 10 mpi ranks. You would just create vectors/matrices with 1
> degree of freedom for the first three ranks and no degrees of freedom for
> the later ranks. During your function evaluation (and Jacobian evaluation)
> for TS you will need to set up the appropriate communication to get the
> values you need on each rank to evaluate the parts of the function
> evaluation needed by that rank. This is true for parallelizing any
> computation.
> Barry
> Il giorno 20 apr 2021, alle ore 15:40, Matthew Knepley <knepley at gmail.com>
> ha scritto:
> On Tue, Apr 20, 2021 at 9:36 AM Francesco Brarda <
> Hi!
> I tried to implement the SIR model taking into account the fact that I
> will only use 3 MPI ranks at this moment.
> I built vectors and matrices following the examples already available. In
> particular, I defined the functions required similarly (RHSFunction,
> IFunction, IJacobian), as follows:
> I don't think this makes sense. You use "mybase" to distinguish between 3
> procs, which would indicate that each procs has only
> 1 degree of freedom. However, you use x[1] on each proc, indicating it has
> at least 2 dofs.
> Thanks,
> Matt
> static PetscErrorCode RHSFunction(TS ts,PetscReal t,Vec X,Vec F,void *ctx)
> PetscScalar f;//, *x_localptr;
> const PetscScalar *x;
> PetscInt mybase;
> ierr = VecGetOwnershipRange(X,&mybase,NULL);CHKERRQ(ierr);
> ierr = VecGetArrayRead(X,&x);CHKERRQ(ierr);
> if (mybase == 0) {
> f = (PetscScalar) (-appctx->p1*x[0]*x[1]/appctx->N);
> ierr = VecSetValues(F,1,&mybase,&f,INSERT_VALUES);
> if (mybase == 1) {
> f = (PetscScalar) (appctx->p1*x[0]*x[1]/appctx->N-appctx->p2*x[1]);
> if (mybase == 2) {
> f = (PetscScalar) (appctx->p2*x[1]);
> ierr = VecRestoreArrayRead(X,&x);CHKERRQ(ierr);
> ierr = VecAssemblyBegin(F);CHKERRQ(ierr);
> ierr = VecAssemblyEnd(F);CHKERRQ(ierr);
> Whilst for the Jacobian I did:
> static PetscErrorCode IJacobian(TS ts,PetscReal t,Vec X,Vec Xdot,PetscReal
> a,Mat A,Mat B,void *ctx)
> PetscInt mybase, rowcol[] = {0,1,2};
> ierr = MatGetOwnershipRange(B,&mybase,NULL);CHKERRQ(ierr);
> if (mybase == 0) {
> const PetscScalar J[] = {a + appctx->p1*x[1]/appctx->N,
> appctx->p1*x[0]/appctx->N, 0};
> ierr =
> MatSetValues(B,1,&mybase,3,rowcol,J,INSERT_VALUES);CHKERRQ(ierr);
> if (mybase == 1) {
> const PetscScalar J[] = {- appctx->p1*x[1]/appctx->N, a -
> appctx->p1*x[0]/appctx->N + appctx->p2, 0};
> ierr =
> if (mybase == 2) {
> const PetscScalar J[] = {0, - appctx->p2, a};
> ierr =
> ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> if (A != B) {
> ierr = MatAssemblyBegin(B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = MatAssemblyEnd(B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> This code does not provide the correct result, that is, the solution is
> the initial condition, either using implicit or explicit methods. Is
> the way I defined these objects wrong? How can I fix it?
> I also tried to print the Jacobian with the following commands but it does
> not work (blank rows and error message). How should I print the Jacobian?
> ierr = TSGetIJacobian(ts,NULL,&K, NULL, NULL); CHKERRQ(ierr);
> ierr = MatAssemblyBegin(K,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = MatAssemblyEnd(K,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = MatView(K,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
> I would very much appreciate any kind of help or advice.
> Best,
> Francesco
> Il giorno 2 apr 2021, alle ore 04:45, Barry Smith <bsmith at petsc.dev> ha
> scritto:
> On Apr 1, 2021, at 9:17 PM, Zhang, Hong via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> On Mar 31, 2021, at 2:53 AM, Francesco Brarda <brardafrancesco at gmail.com>
> wrote:
> Hi everyone!
> I am trying to solve a system of 3 ODEs (a basic SIR model) with TS.
> Sequentially works pretty well, but I need to switch it into a parallel
> version.
> I started working with TS not very long time ago, there are few questions
> I’d like to share with you and if you have any advices I’d be happy to hear.
> First of all, do I need to use a DM object even if the model is only time
> dependent? All the examples I found were using that object for the other
> variable when solving PDEs.
> Are you considering SIR on a spatial domain? If so, you can parallelize
> your model in the spatial domain using DM. Splitting the three variables in
> the ODE among processors would not scale.
> computation.
> Barry
> Hong (Mr.)
> When I preallocate the space for the Jacobian matrix, is it better to
> decide the local or global space?
> Best,
> Francesco
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
> Stefano
> their experiments lead.
> -- Norbert Wiener
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210429/44c51617/attachment-0001.html>
