[petsc-users] Nesting splits based on IS
Karin&NiKo
niko.karin at gmail.com
Tue Apr 27 10:48:27 CDT 2021
It is crystal clear when I am reading you. I will try it on my small test
and I will let you know how it goes.
Thanks for your help,
Nicolas
Le mar. 27 avr. 2021 à 16:55, Matthew Knepley <knepley at gmail.com> a écrit :
> On Tue, Apr 27, 2021 at 9:58 AM Karin&NiKo <niko.karin at gmail.com> wrote:
>> I will have a look at PetscSection (that I have never used before).
>> The FE I use are P2-P1-P1-P1 Lagrange elements. The point is that the
>> numbering of the unknowns is done by the application (I do not have the
>> hand on it). At the moment, I build IS in order to define the different
>> fields and I nest them programmatically in order to set some recursive
>> preconditioner.
>> To enable the use of the command line options in order to nest the splits
>> is a matter of elegance and smoothness since the nesting of splits I have
>> programmed are fully fixed.
> Okay, PetscSection should be completely adequate for that. You just
> 1) Create a Section with 4 fields and give 1 dof/vertex for each field,
> and 1dof/edge for the first field (have to also set the cumulative dofs per
> point)
> 2) SectionSetUp()
> 3) Add a permutation if necessary to the points to get the dof ordering
> you want
> Does this make sense?
> Thanks,
> Matt
>> Nicolas
>> Le mar. 27 avr. 2021 à 14:15, Matthew Knepley <knepley at gmail.com> a
>> écrit :
>>> On Tue, Apr 27, 2021 at 2:51 AM Karin&NiKo <niko.karin at gmail.com> wrote:
>>>> Dear PETSc Team,
>>>> I am coming back to you to get some clue on the (missing?) Fortran
>>>> interface to the DMShellSetCreateSubDM routine.
>>> Yes, we will have to put that in. Fortran bindings for callbacks are
>>> somewhat involved.
>>> However, it is easier if you layout can be described by a
>>> PetscSection (which has all the Fortran bindings). Then it will
>>> work automatically from the DMShell (I think). What kind of layout were
>>> you looking for?
>>> Thanks,
>>> Matt
>>>> Thanks,
>>>> Nicolas
>>>> Le dim. 25 avr. 2021 à 18:20, Karin&NiKo <niko.karin at gmail.com> a
>>>> écrit :
>>>>> Dear Petsc Team,
>>>>> I have begun to write a small test to illustrate the use of a DMShell
>>>>> in order to nest splits from the command line.
>>>>> I am writing it in Fortran because the targeted application is also in
>>>>> Fortran.
>>>>> => I am afraid that DMShellSetCreateSubDM lacks a Fortran interface.
>>>>> Am I wrong ? Can't the interface be generated by bfort ?
>>>>> Thanks,
>>>>> Nicolas
>>>>> Le lun. 19 avr. 2021 à 12:28, Matthew Knepley <knepley at gmail.com> a
>>>>> écrit :
>>>>>> On Sun, Apr 18, 2021 at 11:54 PM Barry Smith <bsmith at petsc.dev>
>>>>>> wrote:
>>>>>>> Matt,
>>>>>>> I agree it can be done with DMs, but I am not convinced that is
>>>>>>> necessarily a superior way when one has to make DMSHELLS and mess around
>>>>>>> with their behavior.
>>>>>>> One way to look at PCFIELDSPLIT is that its basic splitting tool
>>>>>>> is IS and DM is a way of generating IS that can be used for PCFIELDSPLIT.
>>>>>>> In this approach PCFIELDSPLIT needs a bit more support for IS and nesting.
>>>>>>> To also help using multiple levels of DM.
>>>>>>> The other way is to view DM and subDM as the basic splitting tool
>>>>>>> for PCFIELDSPLIT but then one has to ask the question how does DM
>>>>>>> communicate its splits to PCFIELDSPLIT? I am too lazy to look at the code
>>>>>>> but presumably with IS, hence the approach above.
>>>>>>> In the traditional Unix software stack approach to code, each
>>>>>>> layer uses the simpler layer below to communicate; so DM uses IS to
>>>>>>> communicate to the layer below (the linear algebra and preconditioners).
>>>>>>> DM is a hugely complicated layer and making it communicate directly with
>>>>>>> the vector level is complex; I like having the IS level in between to
>>>>>>> simplify the software stack and programming model.
>>>>>>> PetscSection makes live more complicated since it is a bit
>>>>>>> disjoint from IS. I've never resolved in my mind what role PetscSection
>>>>>>> plays, is it a level above IS in the software stack that generates IS, does
>>>>>>> it sometimes "skip over" IS to directly talk to linear algebra?
>>>>>>> If you cannot make a cartoon picture of the software stack, with
>>>>>>> all the objects, then I think the software stack is not well designed or
>>>>>>> defined. I fear we cannot make such a cartoon currently.
>>>>>> DM _does_ communicate with PCFIELDSPLIT using IS. I agree with you
>>>>>> that IS is a good object for communication. In PETSc, IS is just a nice way
>>>>>> to pass a list of integers.
>>>>>> I don't think DM is hugely complicated. It does a few simple jobs.
>>>>>> Here it's job is to remember which field each dof belongs to. That is all
>>>>>> we have to worry about.
>>>>>> PetscSection semantically is a linear space with some structure. We
>>>>>> already know we want some structure like this, since we break all linear
>>>>>> spaces in PETSc into processes. Section allows you to break it down a
>>>>>> little finer into the pieces of the space for each "point", where you can
>>>>>> use a point to mark anything you want, like a process, cell, edge, another
>>>>>> dof, etc. Sections can make an IS when asked a question, such as "which
>>>>>> dofs lie in the closure of this cell", or "which dofs are in this field",
>>>>>> or "which dofs are owned by this process". I have written this in the
>>>>>> manual years ago.
>>>>>> Matt
>>>>>>> Barry
>>>>>>> On Apr 18, 2021, at 8:54 AM, Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>> On Sat, Apr 17, 2021 at 6:13 PM Barry Smith <bsmith at petsc.dev>
>>>>>>> wrote:
>>>>>>>> So you would like to be able to create three IS in your code and
>>>>>>>> attach them with names to the PC. Then have -pc_fieldsplit_XXX_fields be
>>>>>>>> able to utilize the attached IS by name and use them to define the blocks.
>>>>>>>> This is all doable and could be added to PCFIELDSPLIT without too
>>>>>>>> much code, new code. The code would be largely like
>>>>>>>> PCFieldSplitSetRuntimeSplits_Private.
>>>>>>>> The recursive part may also be doable but I think your syntax
>>>>>>>> below is not exactly right. You would need something like
>>>>>>>> -fieldsplit_0_pc_type fieldsplit // split the first PC into a
>>>>>>>> fieldsplit
>>>>>>>> -fieldsplit_0_pc_fieldsplit_0_fields xxx
>>>>>>>> -fieldsplit_0_fieldsplit_0_pc_type jacobi
>>>>>>>> -fieldsplit_0_pc_fieldsplit_1_fields yyy
>>>>>>>> etc
>>>>>>>> this would split the first field into two fields and use jacobi on
>>>>>>>> the first field.
>>>>>>>> The problem is what to use for labelling the xxx and the yyy?
>>>>>>>> I think one could achieve this by having the PCFIELDPLIT attach to
>>>>>>>> each of its split PCs the appropriate modified IS with names attached to
>>>>>>>> them. There are two cases,
>>>>>>>> when building the split uses first all the entries from
>>>>>>>> fieldsplit_v_, then from fieldsplit_p_ then the new ISs it needs to attach
>>>>>>>> to the first split PC are two sets of integers the first from 0 to the
>>>>>>>> len(v)-1 and the second from len(v) to len(v)+len(p)-1.
>>>>>>>> when building the split it interlaces the indices from v and p
>>>>>>>> (interlacing only make sense if the size of v and p is the same). Then the
>>>>>>>> new v would be {0,2,4,...} and p would be {1,3,...}.
>>>>>>>> If you are ambitious and would like to add this to fieldsplit.c
>>>>>>>> we'd be very happy to receive an MR. It might even lead to allowing us to
>>>>>>>> simply how the PCFIELDPLIT interacts with DMs. If all the split type,
>>>>>>>> stride, named, etc are handle in a single consistent manner.
>>>>>>> Barry, this is already working with DMs, which I think is the right
>>>>>>> way to do this.
>>>>>>> Here is the code:
>>>>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/fieldsplit/fieldsplit.c#L420
>>>>>>> The DM must respond to DMCreateSubDM(). The interface is that the
>>>>>>> call provides a list of fields [f_0, f_1, ...]
>>>>>>> and the DM returns an IS for that combination and a subdm for it.
>>>>>>> The subdm part is what allows you to do this
>>>>>>> recursively, since you make the same call on the subdm.
>>>>>>> If you use a PetscSection to keep track of the data layout, the code
>>>>>>> to do field selection is already done:
>>>>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/interface/dmi.c#L105
>>>>>>> which can just be called from the DMCreateSubDM() implementation.
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> Barry
>>>>>>>> > On Apr 17, 2021, at 11:53 AM, Karin&NiKo <niko.karin at gmail.com>
>>>>>>>> wrote:
>>>>>>>> > Dear PETSc users,
>>>>>>>> > I use the fieldsplit PC in an application where the splits are
>>>>>>>> programmatically defined by IS using PCFieldSplitSetIS. Then the user can
>>>>>>>> specify its own PC at runtime using PETSc options.
>>>>>>>> > My question : is it possible to define nested splits in this case
>>>>>>>> as it can be done with strided splits (see snes/examples/tutorials/ex19.c
>>>>>>>> with test suffix fieldsplit_4).
>>>>>>>> > In order to be perfectly clear : let's say I have a 3 fields
>>>>>>>> problem : velocity (v split), pressure (p split) and temperature (t split).
>>>>>>>> > What I would like to do is something like the following but it
>>>>>>>> fails :
>>>>>>>> > -ksp_type fgmres
>>>>>>>> > -pc_fieldsplit_type multiplicative
>>>>>>>> > -pc_type fieldsplit -pc_fieldsplit_0_fields fieldsplit_v_,
>>>>>>>> fieldsplit_p_ -pc_fieldsplit_1_fields fieldsplit_t_
>>>>>>>> > -prefix_push fieldsplit_0_
>>>>>>>> > -ksp_type fgmres
>>>>>>>> > -pc_fieldsplit_schur_factorization_type upper
>>>>>>>> > -pc_type fieldsplit
>>>>>>>> > -pc_fieldsplit_type schur
>>>>>>>> > -pc_fieldsplit_schur_precondition a11
>>>>>>>> > -prefix_pop
>>>>>>>> > -prefix_push fieldsplit_1_
>>>>>>>> > -ksp_type fgmres
>>>>>>>> > -pc_type jacobi
>>>>>>>> > -prefix_pop
>>>>>>>> > -prefix_push fieldsplit_v_
>>>>>>>> > -ksp_type fgmres
>>>>>>>> > -pc_type gamg
>>>>>>>> > -prefix_pop
>>>>>>>> > -prefix_push fieldsplit_p_
>>>>>>>> > -ksp_type fgmres
>>>>>>>> > -pc_type jacobi
>>>>>>>> > -prefix_pop
>>>>>>>> > I thank you for your help,
>>>>>>>> > Nicolas
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210427/077eba2f/attachment.html>
